Old 06-17-2009, 08:22 PM   #1 (permalink)
Member Number: 68105
Default Cant find drain on my neon, found a solution....???
Hi guys, car is a 99 Neon 2.0L turbo with MegaSquirt1 and there is a drain on the accessories, can't find exactly where so just running the accessories on key 1. it's my track car so I dont care much about the radio settings.
What I do care about is that everytime I remove the battery the MS1 takes time before it lights up, like some kind of wake-up mode. Does the MS1 always have to have power memory going to it?
And if it does need power/ground....which wires should I connect
badmannersgod is offline   Reply With Quote
Old 06-28-2009, 02:09 PM   #2 (permalink)
emills24's Avatar
Member Number: 29630
I dont believe there are any wires that are part of a keep alive mem. Also it should not take time to light up the MS it should as soon as it gets 12v. I would test the power and ground source to the MS and turn the key on, verify 12v instantly! If not move to a good source hope that helps!
Udates on my car
http://www.srtforums.com/forums/showthread.php?t=389598
Rage Technologies
rage-tek.com
emills24 is offline   Reply With Quote
Old 07-12-2009, 11:32 AM   #3 (permalink)
Member Number: 64982
Check the relay box under the hood it could be the ignition fure is bad. I had the same problem and had to replace the box itself even tho the fuse was good.
cuwa is offline   Reply With Quote
Page generated in 0.12802 seconds with 13 queries
