Old 04-24-2008, 11:25 PM   #1 (permalink)
zeeboid's Avatar
Member Number: 23169
Default Assistance with Timing advance
Hey all. this is the timing I have. I am told it is quite conservative, and I am looking to get it closer to on-the-stock-side for timing.
at one point, I found on these forums the stock SRT maps, but it has been a while, and I have not been able to re-find these in the last hour. Advice?
98 Grand Prix GTP 240whp 270ft/lbs
98 Neon R/T SRT Swap 259whp 299ft/lbs
SOLD - 01 WS6 Trans Am 349whp 362ft/lbs
95 Tahoe, 05 PT Convertable, 93 Forrester Baha 21 5.7ltr, lawn mower, snow blower, gas weed wacker.
Cylinder Count: 33
zeeboid is offline   Reply With Quote
Old 04-25-2008, 12:57 AM   #2 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
AFAIK this is a stock timing map someone posted, its not MS format but you can use the info. Its an AEM map.
Do you have a stock SRT4 motor? What kind of octane gas do you plan to run? These things will help you decide where to go when adjusting the map
Project log pics
Old 04-25-2008, 06:50 AM   #3 (permalink)
zeeboid's Avatar
I do have a stock SRT motor with Megasquirt and bigger injectors. I plan on running 92 octane.
Old 04-25-2008, 11:17 AM   #4 (permalink)
Member Number: 14309
zeeboid,
Slowly advancing your timing. Do not just jump and start using a lot of timing like you may see on that table. That's where I started, and have advanced it further from there. All the advance was working for me when it was cooler (here in Michigan), but now as the weather warms up, I'm noticing more knock and as a result, I've pulled ~5-10 degrees of timing from what I was running before. In some areas I have less timing now than what you see on that table.
Just my $0.02
Quote: Originally Posted by moltenice
. . . And the PCM knows.... THE PCM KNOWS ALLLLLLLLLLLLLLLLLLLLLLLLLL
I farted once and the PCM pulled timing on me until i rolled down the window... so go figure...
2K4NightRiderSRT is offline   Reply With Quote
Page generated in 0.12996 seconds with 13 queries
