Old 09-29-2008, 07:38 AM   #16 (permalink)
Member Number: 38100
Quote: Originally Posted by SpeedEuphoria View Post
Hey Guillaume, I did not know you have a SRT4 now.
Do you still have the Omni?
No, i sold it to a local TD fanatic Sc-6152SP and MS run very strong.
Now i work on a plug'n play harness for SRT/MS.
I plan to put a A413 in my SRT to see how it will run whit the stock turbo.
And you what going on?
turbogui is offline   Reply With Quote
Old 10-11-2008, 08:19 AM   #17 (permalink)
Member Number: 39105
Sorry to not update. It was just too costly to get the plugs made that I would need to do it, and it wasn't worth going to every junkyard in the area to get every ECU and plug to do this. Considering I (ASP) have only been able to sell 1 SOHC turbo kit even at a lower price point than Hahn but with more features and power, I'm very reluctant to dump a couple grand into this project to see $400 come back.
esteinmaier is offline   Reply With Quote
Old 10-11-2008, 11:37 AM   #18 (permalink)
killaneon's Avatar
Member Number: 62141
just use junkyard plugs
holset h1c
dsport
built motor
ported head
3inch exhaust
=3rd gear burnouts on the highway
killaneon is offline   Reply With Quote
Old 10-29-2008, 01:03 AM   #19 (permalink)
Member Number: 17276
Trader Rating: (41)
Quote: Originally Posted by cododgeneon View Post
Hey Eric why not offer this for us 1st gen guys? What we arent fast enough for you?
Do you have a schematic of the pins for the 1st gen??
SilverSerfer is offline   Reply With Quote
Old 11-24-2008, 07:58 PM   #20 (permalink)
Hey here my almost ready to go plug n' play harness for srt! Will run very soon!
Old 11-24-2008, 09:11 PM   #21 (permalink)
Trader Rating: (41)
Looks just like the one i'm working on. Looks good man! I had the hardest time finding the stupid pins...Oh and getting the PCM side connector is a pain in the ass....
Good Job man!
Old 11-25-2008, 11:45 AM   #22 (permalink)
Thank you!
Here what My MS will do :
Read the coolant and IAT and still get the dash working
Read stock NGC
Fan driver
Boost control output for AEM solenoid
Fuel - spark : 1 table of each for begin
Already have the Cold start run great on a 2.4 T so i wil be ok
577cc tune & 682cc tune
Stage 1 or 3 spark table.
Lauch control & flat shift control
Adjustable REV limiter.
Antilag is now present un Hr11C1
I forgot ....too much too list!
Old 11-28-2008, 11:59 AM   #23 (permalink)
New update on temp reading whitout bias resistor. I have do some test and i think i found the internal bias resistor value of the Dodge PCM
Test was so with a 10k Resistor on the coolant plug.
Here result :
Open circuit= 5V so the PCM use 5V for temp divider.
10k resistor in = Voltage on the resistor = 3.565 and the real value is 9.87K
I draw across the circuit is 355 uA.
So: 5V - 3.565V = 1.435v / 355uA = 4042 Ohms!
If i use only resistor value:
3.656V / 9.87K = 361uA
1.435v / 361 uA = 3975 Ohms!
The internal resistor for bias is 4K.
It's time for Easytherm now and check if the value is like the pcm reading!
Old 11-28-2008, 09:36 PM   #24 (permalink)
Trader Rating: (41)
Here result :
Awesome news! Now the flat shifting is that for Wide open throttle shifting where it cuts fuel and spark for the time you shift?
Old 11-28-2008, 09:54 PM   #25 (permalink)
Yes that what flat shift do.
NB: the calculation i have do in the previous post is to share coolant and IAT sensor across stock PCM and Megsquirt. ( for the one that not know)
Old 11-30-2008, 12:04 AM   #26 (permalink)
killaneon's Avatar
awesome stuff. i got ready to order a megasquirt kit, but the diablo seems so eazzzzzzzzyy.
i do know that you can tune better with ms though
Old 11-30-2008, 09:18 AM   #27 (permalink)
Seriously, if you don't have electronics skill....go with Diablo!
MS is a lot of time..but i love it
Very flexible and cutomisable.
Old 11-30-2008, 10:51 PM   #28 (permalink)
killaneon's Avatar
i haz ultimate skillz with a soldering iron.
i put a jaw unit together(easy)
the only problem is a ms kit with all the stuff for a clean install will be about 300$
and the diablo can be had for 320 at certain renegade dealerships
NOT trying to thread crap really just trying to discuss the pro's and cons
Old 12-01-2008, 08:33 AM   #29 (permalink)
Member Number: 319
If you have a race or radical street car and aren't real concerned with passing emissions a MS (or any other stand alone) will give you a lot more control. You'll get things like 2-step rev limiter, programmable input/outputs for things like nitrous/water injection control, etc.
However, for a mainly street driven car that needs to pass emissions a diablo or SCT setup would be better.
Old 12-01-2008, 11:01 AM   #30 (permalink)
And Ms need work, you must customize your code for different need, and do all the mod on the board for what you need..
IMO for every day SRT owner..diablo is much better... For the people like me that like do it all by themself and control 100% of the engine MS .
Page generated in 0.18414 seconds with 13 queries
