Old 04-12-2009, 07:45 AM   #1 (permalink)
holmes14's Avatar
Member Number: 64416
Default Where is this AEM boost solenoid wired to? help with uninstall?
Hey guys, I switched to a DSP and im really liking it so far. But the one problem im having is controlling boost. I guess people have been having problems having the pcm control boost. So I was looking at taking out the aem solenoid but i cant find anywhere it would have been spliced in? the two brown wires just go into the factory wiring harness that looks like its never been messed with, and if i just cut the 2 brown wires i wouldnt know where to put them too, or where the stock boost solenoid even is. (I assume the previous owner didnt remove the stock boost solenoid?) Any help? Suggestions?
Id almost like to just go MBC but ive heard how they arent very consistent with boost. Even right now its like 15psi in 1st 20psi in second and 25 in 3rd. But im not sure why. So how bad is a MBC, or whats a good cheap EBC?
holmes14 is offline   Reply With Quote
Old 04-12-2009, 08:07 AM   #2 (permalink)
d_fl8ted1's Avatar
Member Number: 11549
Trader Rating: (81)
i believe it is the pw2 slot on the connections you will have to splice into... the color is DB/GY if i remember and you will need to ground the other side... just one wire to that and a ground... good luck
On the 8th day GOD created drag racing
d_fl8ted1 is online now   Reply With Quote
Old 04-12-2009, 08:12 AM   #3 (permalink)
d_fl8ted1's Avatar
Trader Rating: (81)
but please double check my info... been awhile since i wired mine in..
Old 04-12-2009, 08:56 AM   #4 (permalink)
holmes14's Avatar
I heard aem now says that you dont need a ground and that polarity doesnt matter you can hook up either wire to either spot on the aem. Or are you talking about after uninstalling it? The AEM solenoid is already installed but i dont see anywhere its spliced into?
Old 04-12-2009, 02:19 PM   #5 (permalink)
holmes14's Avatar
Could i just put the vaccum lines to a manual one and leave this one there since i dont know if they removed the factory boost solenoid?
Page generated in 0.14926 seconds with 13 queries
