Old 08-09-2009, 11:49 AM   #1 (permalink)
stxsrt's Avatar
Member Number: 37057
Trader Rating: (38)
Default What's your 2-step at, and how much boost do you build?
Just wanted to see what other peoples settings where. I just installed the PEMS on the SRT and wondering how much boost your seeing at launch..
These are my mods
Engine: JE pistons, Eagle Rods (stock CR)
Valve Train: Crane (Crane 14)
Turbo (47LB E3) Going with a 65mm turbo or larger soon
Boost: 3-4 psig
Fuel Cut: 4400
Ign Cut: 4400
Retard Rev: 4400
I like lauching at that RPM mainly because of the short gearing in 1rst on the T850 trans.. When I raise it to 5300 (2 step) I build maybe 9 psi.. Is there anyway to get 9-10 psi at only 4300 rpms? I can always do anti- lag but dont want to go that route as yet haha
7.3 @ 101 1/8 mile
http://www.youtube.com/watch?v=RUBJUpApyeE
AEM EMS Tuned by Tampamike
E3 Turbo
Crane 14 cams
M&H Slicks 24s
stxsrt is online now   Reply With Quote
Old 08-09-2009, 09:26 PM   #2 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
These are my mods
Boost: 3-4 psig
Fuel Cut: 4400
Ign Cut: 4400
Retard Rev: 4400
there is the drag anti-lag that will help you build boost just dont use the rally anti lag
Old 08-10-2009, 05:39 AM   #3 (permalink)
stxsrt's Avatar
Trader Rating: (38)
Yes I already know about antilag and I dont want to use it haha, do you use the 2 step on the AEM? if so how much boost do you build and at what RPM
Old 08-10-2009, 02:01 PM   #4 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (73)
Whats the disadvantage to anti lag?
Old 08-10-2009, 02:26 PM   #5 (permalink)
tavenger5's Avatar
Member Number: 42245
Trader Rating: (29)
I'm set at 5400 and I'm only getting 2.5psi. hrm
[font="Arial Narrow"]
2004 Black SRT-4 - all set for 500hp+
2005 Interlagos Blue BMW M3
tavenger5 is offline   Reply With Quote
Old 08-10-2009, 06:57 PM   #6 (permalink)
nutz's Avatar
Trader Rating: (19)
EGT get super high and will melt anything
Old 08-10-2009, 07:41 PM   #7 (permalink)
stxsrt's Avatar
Trader Rating: (38)
I have mine on level 10 hard cut, wheres your setting at?
Old 08-10-2009, 08:29 PM   #8 (permalink)
Trader Rating: (73)
I suppose that makes a lot of sence when you think about it.
Can 116 combat that to a certain degree?
Old 08-10-2009, 08:38 PM   #9 (permalink)
nutz's Avatar
Trader Rating: (19)
na, higher octane fuel should burn slower and make it worse, less than 1/4 second in the stageing lanes is fine as long as you have no cat
Old 08-10-2009, 08:55 PM   #10 (permalink)
tavenger5's Avatar
Trader Rating: (29)
err, where's that setting even at? I don't know if I want to launch at more boost though, I already can't get traction even with slicks.
Old 08-10-2009, 09:05 PM   #11 (permalink)
stxsrt's Avatar
Trader Rating: (38)
Haha my best pals here has a mitsubishi with a precision 62mm turbo charger that uses Antilag and builds 20+ psi in like 2 seconds Lol. He gets his Aem tuned by Turbotrix in Jersey blah, blah but this thread is not about antilag.. Hopefully someone can answer my original question about building more than 5 psi at around 4500 rpms bump!
Old 08-11-2009, 04:57 PM   #12 (permalink)
nutz's Avatar
Trader Rating: (19)
sorry dude its 100% dependent on the amount of exhaust gas, and at 4500 5 psi is about all your gonna get (it will varry a great deal from build to build), using anti lag is a great option to build boost on the line, you could do a poor man anti lag and retard the ignition and add fuel in the area where you 2step it but this will kill your drivability
anti lag is only extra fuel and a very retarded ignition, this will will allow the A/F mix to expand in the exhaust manifold and not the combustion chamber and yes it will make you spool very fast but the motor will not have power untill you come out of anti lag and by that time there is a ton of inirtial energy built up, i played with it for a while and 20psi is easy to build but will eat a motor (valves and turbine) in a couple seconds, while using the rally anti lag (do not try this) my car would hit 20+ at 2k rpm but would take till 2500 to make power (ecu returns timing and lowers fuel) with out it i would spool 20 at around 3300 (800 rpm added to power band)
its how you use the timing and fueling, if you want drop the timing 2-3* and add about 10% fuel in the area where you are trying to build boost. just remember to smooth out the map when your done
not sure of what your question was but i hope this helps a bit
hint: i would use a switch and drag anti lag as to not fuk up your maps
Old 08-12-2009, 10:22 PM   #13 (permalink)
NachO_SRT's Avatar
Member Number: 8662
If you want to build more boost try dropping retard rev 250 RPM below ign cut
NachO+
Daily Driver -2009 SWP WRX STi + Gold BBS's
Road Course Car. 2004 E-blue SRT-4, Mods and pics: CLICK
7/18/09 - 507/468 - S259 Fuel E85 - Meanblueberry.
STOCK:308/396 - 5/17/2009 E-85, Stock turbo
NachO_SRT is offline   Reply With Quote
Old 08-15-2009, 07:54 PM   #14 (permalink)
stxsrt's Avatar
Trader Rating: (38)
I lowered the rev retard by 100 rpms and gained about 5 psi thanks Nacho!
Old 08-16-2009, 06:59 AM   #15 (permalink)
NachO_SRT's Avatar
Member Number: 8662
Your welcome. N-joy the boost!
NachO
Page generated in 0.20662 seconds with 13 queries
