Quote: Originally Posted by
reysrt4
i meaured the voltage on the sensor but the meter i have only measured the whole no.(3volts), i read on the instructions, that the uego measures 3.96 and with it unplugged ,i set the gain on the ems to about 1.67(with the ignition to the on position snd not running)until the voltage on the ems parameter said 3.96v. after starting the car, i just can't get the wideband and the ems to see the same a/f. i do have low gas due to the car being in storage. but when i put gas in, then both the wideband and the ems will change. i did change the numbers on the cal. table since they were way off. can someone lend a hand, so that i can get this right? by the way i did change gain settings from 1 and up to 2, to change the voltage, but the ems stays in the 15-17.8 range and my wideband stays between 12-14 range.
that gain sounds way off. when you measure the voltage with the sensor unplugged at the pcm it should read somewhere around 2.XX volts.
the gain is usually somewhere around .8 - 1.1 i dont think i have ever seen it higher.
also and this goes for everyone
the ground for the aem wideband MUST BE A SUFFICIENT GROUND!!!!
if the ground is not good you will never read right and 02 feedback will be way off.
what i usually do is run the ground for the wideband directly to the battery ground and i also run extra grounds from the battery to the pcm sensor grounds.
