i keep my off tps % just above what the TPS V is closed
not sure what you want to do
you want the pops and farts ???????
if so i would raise the fuel off RPM to ...IDK say 3500rpm (it will fart and burp below)
then go into decell pump and raise the decell decay (10-15%)
that will make your car pop ??????
as for the start up, you would need to look at the start maps
try to raise the crank injector time table has enough extra fuel
also check your start retard (crank adv) i use about -2 (make sure its a negative #)
and i use about 1* extra for about 15 sec. on start up
as for the idle just try to lower it
(idle target base)
IF YOU ARE UNSURE ABOUT ANYTHING DONT TOUCH IT AND ALWAYS SAVE YOUR LAST GOOD TUNE TO FALL BACK ON IF YOU SCREW IT UP
your best bet is to E-mail jay if he tuned your car, with the EMS there are 100 different ways to tune it and everyone uses different stratigys (jays is the best i have seen from the forums)
