Old 04-21-2009, 08:11 AM   #1 (permalink)
slow_turbo_z's Avatar
Member Number: 63089
Trader Rating: (12)
Default Stuck Boost Control and idle
lil background.
Car is an 05 SRt-4, has 590injectors, 3bar mopar map, CIA (AEM), 3inch cut out.
Car runs and drives like a champ, I had local help tuning the basemap for drivability and it seems great, fan seems to kick on alot though.Free File Hosting Made Simple - MediaFire
Okay, so I'm new to the EMS, I've exhausted all the reading I can do.
Problem one, at idle my target afr's should be 14.5, why do I keep hitting 12.9, 13.3?
Second Question I've zero'd out anything to do with boost targets and anything related to boost control, I'm trying to get low boost so I can build from there and it wants to just give full boost no matter what.
Drag Racing is Only Boring in Slow Cars
slow_turbo_z is offline   Reply With Quote
Old 04-21-2009, 08:11 AM   #2 (permalink)
Trader Rating: (12)
The link in there is my cal file
Old 04-23-2009, 09:42 PM   #3 (permalink)
relenger's Avatar
Member Number: 30003
Some one will chime in, i know when i wanted to run low boost i just hooked my WG to the compressor side nipple... stock turbo i think can go as low as 5psi..
as far as setting up the AEM EMS, Notta clue....
The Cobalt firmly grabs you and whisks you along your way instantly.
It does so with authority and poise, but while slipping relatively unnoticed through traffic,
never being violent, or dare I say it, frightening. When you ask the SRT-4 to take you somewhere fast,
it punches you in the face, throws you over its shoulder, and runs, screaming,
so quickly that its tires can barely keep up
relenger is offline   Reply With Quote
Page generated in 0.13426 seconds with 13 queries
