Old 05-28-2008, 07:52 PM   #1 (permalink)
mebcop's Avatar
Member Number: 42028
Trader Rating: (10)
Default Problems ALREADY!!!
Well, my car was tuned yesterday and today. It put down 383hp and 433tq on a Mustang dyno at 12:1 AFR. Well, I drive it home and I do a few pulls on the way... WOW, it was fast. Well, I get home and let the car sit a couple hours. I take the wife out to show her how it pulls now and the first pull overshoots the boost by a few pounds and it was pulling good with really good air fuels. I go turn around and on the way back I launch it, but not too hard. Well, the air fuels are now at 10:1 and stay there almost to redline where they lean out to 11:0. I don't think I've ever had a car go too RICH all of a sudden!!! I thought maybe I blew an intercooler hose off or a vacuum line, but I checked them all and they were all fine. I have to make a new boost leak tester for my 50 trim inlet, but before I do that, what do you guys think could have happened??? It's GOT to be a boost leak. I sprayed carb cleaner around the intake manifold and throttle body and there was no change in idle at all.
ANY suggestions would be appreciated!!!
AGP return line, AEM SRI, AEM UEGO Wideband, VRS 3 inch Exhaust, Maxxfab 3" DP w/o cat, DW 750's, MPx FMIC , 50 Trim AGP, HKS SSQ BOV, Turbonetics evolution wastgate, OBX IC pipes, Labonte Motorsports W/M kit, SBC Stage 5 clutch, Perrin MBC, Maddog 80% STS, bottleneck fix, walbro 255, Bwoody MM, AEM 3.5bar Map Sensor, Rage-Tek Map Sensor Adapter.EMS INSTALLED: 433 WTQ ON A MUSTANG DYNO UNCORRECTED WTB:TRACTION HAHAHA
mebcop is offline   Reply With Quote
Old 05-28-2008, 08:10 PM   #2 (permalink)
Aceburner's Avatar
Member Number: 52066
If everything is working fine then you might want to consider the enviornment u were in when u tuned. I'm not that much of a dyno guy but if you tuned your car on a dyno, I'm sure that when you drive the car on the street, you are going to have different AFR's. I street tune because you get a more accurate tune based on the elements you actually drive in. I may be wrong but I've seen it happen a couple times.
Aceburner is offline   Reply With Quote
Old 05-28-2008, 08:14 PM   #3 (permalink)
mebcop's Avatar
Trader Rating: (10)
But it was running perfect on the street for the first couple hours, then ALL OF A SUDDEN RICH AS HELL
Old 05-28-2008, 08:34 PM   #4 (permalink)
SRTforums Veteran²
onthedwnlow's Avatar
Member Number: 27125
Trader Rating: (46)
nothing in the tune should have changed and messed the tune up......it has to be something in the setup.....and i dont know what to tell you there......are you using the ems for boost control?
sorry guys but the car is for sale....all out first gen is in the works
onthedwnlow is offline   Reply With Quote
Old 05-28-2008, 08:36 PM   #5 (permalink)
mebcop's Avatar
Trader Rating: (10)
not yet perrin ceramic b/s mbc
Old 05-28-2008, 08:39 PM   #6 (permalink)
SRTforums Veteran²
Trader Rating: (46)
why did you not have them tune it on ems bc?......it seriously take 10 minutes to set it up.......if it was over shooting boost it went higher on the boost comp graph where they did not tune.......
Old 05-28-2008, 08:41 PM   #7 (permalink)
mebcop's Avatar
Trader Rating: (10)
But now I turned the boost down to 18psi from 25 and it's still pegging the Uego rich at 10:1 AFR and it bucks and chugs when it goes that rich.
Old 05-28-2008, 08:46 PM   #8 (permalink)
SRTforums Veteran²
Trader Rating: (46)
email me your map
onthedwnlow@aol.com
Old 05-28-2008, 08:48 PM   #9 (permalink)
mebcop's Avatar
Trader Rating: (10)
I haven't connected my laptop to the ems since i got home so I don't have it yet.... I'll datalog tomorrow and send you the map and datalog if you don't mind...
Old 05-28-2008, 08:49 PM   #10 (permalink)
SRTforums Veteran²
Trader Rating: (46)
sounds good man
Old 05-28-2008, 09:36 PM   #11 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (47)
how long did you have it running when you went with your wife? you might just have not let it warm up enough.if the warm up enrichment is high that will happen.especially if you have low resolution on the fuel map.try letting it warm up for a while then take it out
Email: Jay@N2MB.com
take a moment today to reflect on what happened on 11 september 2001...
Old 05-29-2008, 03:21 AM   #12 (permalink)
lilmike0450's Avatar
Member Number: 56278
^^^^I agree..gotta let it sit for a few minutes and get the juices flowin...Im glad Im finally figuring this shit out...I bet Eric is too...LOL
05 White ACR
lilmike0450 is offline   Reply With Quote
Old 05-29-2008, 04:37 AM   #13 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (20)
Mustang Dynos provide load just like a car would see on the street in order to give a more accurate tune. They can even account for wind resistance at higher speeds. Every car I've tuned on the local Mustang Dyno the wideband has been exactly the same from dyno to street.
Nigel
04 Srt-4-50 trim, Crane 14s, 635's, Dtec, etc
88 Civic-D15 mini me, full exhaust, weight reduction
Soon to be powered by DIABLO SPORT!
Installs, tuning, and tranny rebuilds done in NC! PM me NOW for GREAT pricing!
http://www.trudynosports.com/customers/nigel.html
Old 05-29-2008, 05:58 AM   #14 (permalink)
mebcop's Avatar
Trader Rating: (10)
I see what you're saying but the first pull with my wife went good, so I don't think that's the problem. On top of this, on my ride into work today, my idle was hanging up at about 2000rpm. If I added some strain on it with a little clutch, I could get it to settle down to about 1300rpm, but yesterday it was idling at about 950rpms??? I wonder if I have a vacuum/boost leak causing this or if that just has to do with some idle adjustment graphs? I have to wait till I'm done work to fiddle with it, so we'll see. Thanx guys.
Old 05-29-2008, 07:16 AM   #15 (permalink)
SRTforums Veteran²
Trader Rating: (46)
im almost 100% sure its a boost leak or something.....something does not seem right
