Old 07-13-2006, 08:50 AM   #1 (permalink)
distinctdev's Avatar
Member Number: 22976
Trader Rating: (32)
Default Part throttle/Cruising timing
Back when I had a stock pcm and a tech guage i was able to see my timing while cruising. I would see it around 50 deg adv. and I dont see #'s like this in the timing maps in vacuum. Also when I would throw my too rich code i would notice the timing go down and the car wouldnt drive as nice so im thinking the car drives better cruising with more timing? Is it ok to advance this as long as I look at knock?
R.I.P. Steven Lorenz 04.04.06
MySlips.com
Bench Racing Stops Here.
distinctdev is offline   Reply With Quote
Old 07-13-2006, 10:30 AM   #2 (permalink)
macsperformance's Avatar
Member Number: 41778
The only proper way to do this friend is with the help of a good load bearing dyno. You can adjust timing and see tractive effort/torque in real time. So you can see the precise point you have hit optimal timing for that load cell. Contrary to popular belief you can not feel 5 ft/lb difference in torque output while attempting to hold the car in a load cell on the street. When a car is tuned properly it will perform better in many conditions than a car that was not properly optimized in every cell on the street.
Chris Macellaro
Macellaro's Performance Tuning
EFI University Instructor
Mustang Video
Camaro Video
MPT Video
Base Fuel Table Tuning Video
macsperformance is offline   Reply With Quote
Old 07-13-2006, 10:41 AM   #3 (permalink)
Member Number: 10737
Chris Macellaro
Reason why you are tuning my car tomorrow
See you tomorrow Chris.
06 WW EVO IX
Flash, Espelir DP, Test pipe/w exhaust cutout, Megan Racing Catback, Apexi Power Intake, Licp, Walbro 255, Greddy Profec EBC, ZT-2
Custom tuned by Chris of www.macellarosperformancetuning.com
300Whp & 300WTQ @ 21 psi pump on DD Dyno
http://www.myspace.com/fastazzevo
Tegr006 is offline   Reply With Quote
Old 07-13-2006, 12:31 PM   #4 (permalink)
Trader Rating: (32)
Chris Macellaro
do you guys visit florida , also looking at the stock aem map, is it really low, maybe we could add 5 degress of timing and even though it might not be the best it would be better. is this possible?
Old 07-13-2006, 04:14 PM   #5 (permalink)
Chris Macellaro
I look forward to seeing you, and thank you.
Have a safe trip and I will see you in the morning.
Chris Macellaro
Old 07-13-2006, 04:21 PM   #6 (permalink)
Yes sir I do travel; No it is actualy pretty close on the low load cruising portion of the map. Make sure your A/F's are in line prior to ignition timing calibration.
Chris Macellaro
