Old 05-30-2009, 05:01 PM   #1 (permalink)
Member Number: 41218
Trader Rating: (15)
Default overboosting
i have been communicating with nemo about this bt i figured i'd come and share . i have my aem set to 25 lbs. and between n2mb's tune and nemo adding some ,so that i can try to figure out why i keep boosting over 30lbs. i get fuel cut due to fuell cut bein set at 30. can anyone relate to this.
reysrt4 is offline   Reply With Quote
Old 05-30-2009, 06:53 PM   #2 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
has it always "overboosted" or is this new ?
did you try new boost control lines or check for tiny leaks,just pressurize your source, i use a compressor with a regulator set to my crack pressure (off boost not manifold pressure) to check the WG function and for leaks.
other than that it could just be your boost control tables (i dont know jack bout that)
what new changes did nemo do, and i presume you save all the maps so you have an original (good tune) map to compare your last map to
Old 05-30-2009, 07:30 PM   #3 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
rey email me a copy of the current cal and ill check it
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 05-30-2009, 07:40 PM   #4 (permalink)
Trader Rating: (59)
theres too much duty cycle in the boost control probably..we set the boost when it had a boost leak
Old 05-31-2009, 03:38 PM   #5 (permalink)
Trader Rating: (15)
i will email you a cal. i wish you were up here or i was down there. remember we had an issue when tuning on the dyno, so it really was always malfunctioning . i connected the wasegate to the turbo and it hit about 13 pounds, then i connected it to the stock solenoid the same way that it is in the picture on the car( with only the bottom of the wastgate connected and it hit 17lbs. i kept getting some kind of cut when hitting on it but i guess that was ignition cut from the 2step.
Old 05-31-2009, 03:50 PM   #6 (permalink)
Trader Rating: (15)
jay check your email, i hope it was sent correct. nemo changed some numbers in the boost map, but that didn't work. jay it may seem as if i messed around with some things here and there. so feel free to correct something if it seems out of place.
Old 06-04-2009, 06:26 AM   #7 (permalink)
Trader Rating: (15)
jay have you gotten my email at all.
Old 06-04-2009, 08:17 AM   #8 (permalink)
Trader Rating: (59)
yes got it, what am i supposed to be looking at in those logs? you never went over 14 psi in them. i looked at the tune and compared it to your tune i gave you and a lot has changed.check your email
Old 06-04-2009, 07:59 PM   #9 (permalink)
Trader Rating: (15)
sorry jay,i sent you logs of the turbo to wastegate connections, showing that the wastegate works . i am sending you a log of the setup with the contoller and you will see that i reach 34 and then i guess i get fuel cut. i had to disengage the wobox due to getting ignition cut earlier.
Old 06-11-2009, 08:09 PM   #10 (permalink)
Trader Rating: (15)
jay have you gotten my log. i hit 26lbs, but af is 13. also, has anyone ever come across frying of coils from runs
Page generated in 0.16592 seconds with 13 queries
