Hey guys, I have finally started to *try* to figured out the AEM some. I started out with the 50 trim tune posted here and it is running okay, driveablity needs work. That may have been something I dicked up over the time by messing with it.
Car, 04
rc750's
255 pump, return line, stock FP and no vacuum line
stock long block
stock intake manifold/TB
AGP race cooler
AGP 50-trim .63 hotside
Cut out
NGK 4306's gapped at .38
Here is a copy of my cal and two logs I just took. It is 81 outside and I am running 93 pump gas.
http://boostedmopar.com/temp/cals/ch...ing_tables.zip
One run is with the timing I have been using. The other run is with 20% less timing. I am trying to figure out how read the knock gauge so I can add more safely add more timing. I'd really like to have a race gas 28psi tune also. I am not sure what is good or bad on the knock.
So far my AF's seems pretty good, The -20% timing tune was getting in the 12's but I am not sure how true that is. The AEM gauge in the car doesn't seem to run a 100% true with what the computer says. I am not sure if I have it set up or adjusted right.
Current problems:
Start up some times kicks back. The start advance was on -0.12 and I just changed it to -0.48 I'll see how it does tomorrow morning.
I also have issues where I'll be going down the road and it just cuts out. I am not sure why. I was having issues with spark blowing out at the top of 3rd so I replaced the plugs. It pulls clean in 3rd now. It seems to have helped with the random cut out but I don't have much driving time since the plug swap. It will still cut out but not it doesn't seem as bad. It will cut out when you are just cruising along in traffic.
I don't understand the o2 feedback. I have it turned on but I am not sure how well it is setup. How does it work? Does it remember what it has learned after you turn the car back on or does it have to learn everything all over again? Is there a way to see what it has learned and then apply the changes to the permanent map? I also don't know what fuel tables should adjusted for boost, idle or driveabilty. I normally just adjust the main fuel table.
A/C adjustment. My idle is pretty good until I have A/C on. It hunts pretty bad when it is on. What are the tricks to getting good idle with the A/C on.
I miss my stage 1 popping and backfiring on decel. Is there a way to get that back?
What target idle should I look for? It doesn't seem to idle good unless it is at 1000rpm, I was wondering what everyone else targets for.
I also messed with the 2 step rev limiter today. I changed the retard a 100 rpm less. It boosts up 15psi in a flash. I was wondering how safe this is for the turbo and what the safe setting should be.
