Old 09-09-2009, 07:34 PM   #1 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (73)
Default Manually 'helping' the IAC idle?
Anyone ever try to adjust the throttle stop on the throttle body to help the IAC work a little less? My local tuner wants me to:
1) Set the idle to 0.50 by adjusting the throttle body(car off)
2) Then unplug iac and see if the car will idle
3) Then view the learned value while car is running with IAC still unplugged
4) Make changes in the % target table until idles where id like.
5) Plug IAC back in so car will idle at 1200...
Seems to make sence to me(maybe i missed a step or too but i know what to do). I dont really ever see anyone talk about it but it makes perfect sence, any adverse effects? Any down sides? Any one do this?
supermech21 is online now   Reply With Quote
Old 09-09-2009, 08:12 PM   #2 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
still having problems with that huh?
if you adjust the screw (throttle stop) just do it untill you see a value in the throttle then adjust the IAC acordingly
I would venture to say if you have a buddy with an srt try to swap the TPS sensor to see if yours is bad it should show a value IDK why yours dosnt when closed
Old 09-10-2009, 12:32 AM   #3 (permalink)
Trader Rating: (73)
Really the car runs quite well!
Goes on the rollers Monday for some pump gas numbers. The higher i take it in the RPM's the better it sounds.
Either way the local tuning it suggested this, i donnu. I bought a brand new TPS re wire and TPS sensor so if i need to go down that avenue i will...
Old 09-13-2009, 08:58 PM   #4 (permalink)
Trader Rating: (73)
I raised it, actually quite well...With the MPx tb theres just a small set screw on the bottem.
Now at idle its at 0.51 - 0.80 ... Havent really played with the tune to much, but i think it feels slightly better.
Old 09-13-2009, 09:12 PM   #5 (permalink)
nutz's Avatar
Trader Rating: (19)
glad to see your reading some voltage now
if iT fluctuates (tps vots) you may need to raise it so 5-6% is closed and when the throttle is about 8/10 of the way down it reads 100% this will lower the amount of volts read by the ECU and slow or eliminate the oscilation and help with DFCO and all over throttle responce (all tables would need to be modified to see 5-6% or what ever at closed throttle)
Old 09-13-2009, 09:53 PM   #6 (permalink)
Trader Rating: (73)
Well i was watching the learned value and it oscillated from -7 to -9 all the way up to 1 -2....Sop its getting better!
Getting pump gas dyno tomorrow, will update! :thumbs up:
Old 09-14-2009, 12:06 AM   #7 (permalink)
nutz's Avatar
Trader Rating: (19)
Old 09-14-2009, 12:21 AM   #8 (permalink)
Member Number: 56959
Why would you want it to idle at 1200? Hell, my car only idles at 950, and I think thats high.
SOT - ಠ_ಠ
paint is offline   Reply With Quote
Old 09-14-2009, 12:28 AM   #9 (permalink)
Member Number: 30696
big cams?
amdguy is offline   Reply With Quote
Old 09-14-2009, 01:10 AM   #10 (permalink)
nutz's Avatar
Trader Rating: (19)
I can only idle at 950 w/ 13", i could only see that high of an idle if the cam is big and the injectors dictate a minimal PW, some of the "reworked" injectors dont like small PW's
Old 09-14-2009, 01:42 AM   #11 (permalink)
Quote: Originally Posted by amdguy View Post
big cams?
Theres only one
Its stock The fact my car shakes at idle is bad motor mounts
Old 09-14-2009, 01:59 AM   #12 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
Theres only one
Please tell me that was a joke...
MY FAVORITE EQUATIONS:
Fuel Volume = (HP * BSFC) / (# of injectors * IDC)
CFM = C.I.D. * RPM * V.E. *.5 / 1728
P.R. = (PSI Boost + 14.7) / 14.7
HP = TQ * RPM / 5252
Old 09-14-2009, 02:06 AM   #13 (permalink)
I guess I have two if you count the stock one sitting in my shed.
Old 09-14-2009, 02:10 AM   #14 (permalink)
Let me get this straight. We are talking about cams, here? And on an SRT-4 (IE. DOHC 2.4L)?
Old 09-14-2009, 02:27 AM   #15 (permalink)
Cam(s)? Yes.
DOHC 2.4L I4? No.
Page generated in 0.19806 seconds with 13 queries
