Old 09-29-2009, 08:37 PM   #1 (permalink)
d_fl8ted1's Avatar
Member Number: 11549
Trader Rating: (81)
Default Manual to auto what changes?
OK on my tune with the switch from the manual to the auto ... what do i need to change in the aem to compensate for the switch... I am trying to learn so be gentle... LOL
How do i utilize the auto function on the aem?
On the 8th day GOD created drag racing
d_fl8ted1 is offline   Reply With Quote
Old 09-29-2009, 08:50 PM   #2 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
your reverse manuel with a brake right ?
Old 09-29-2009, 08:51 PM   #3 (permalink)
d_fl8ted1's Avatar
Trader Rating: (81)
Yes it will be the reverse manual valve body with foot brake...
Old 09-29-2009, 08:58 PM   #4 (permalink)
nutz's Avatar
Trader Rating: (19)
OK not sure but I will ask around so not T-brake solanoid
Old 09-30-2009, 07:16 AM   #5 (permalink)
d_fl8ted1's Avatar
Trader Rating: (81)
nope... not trans brake... or at least i dont think the dcr comes with a trans brake...
Old 09-30-2009, 02:06 PM   #6 (permalink)
nutz's Avatar
Trader Rating: (19)
you would know (push button reverse)
Old 09-30-2009, 02:32 PM   #7 (permalink)
d_fl8ted1's Avatar
Trader Rating: (81)
well i havent recieved the transmission yet it is supposed to ship out this week... i am just wanting to get everything ready... but i don tremember them saying it has a transbrake.. so i am going to assume no...
Old 09-30-2009, 02:44 PM   #8 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (431)
There is nothing you need to change other than your tune
www.Realtuned.com
Each car built/tuned/track prepped in house
{11.62@128 Realtune Caliber}{11.85@119 Whoosh@Realtune Caliber}
Home of the Worlds Quickest/Fastest CSRT-4, Manual NSRT4, and Stock turbo SRT4
Old 09-30-2009, 03:02 PM   #9 (permalink)
d_fl8ted1's Avatar
Trader Rating: (81)
ok so i wont use the auto function at all... gotcha...
just need to tweak the air/fuel and maybe timing?
Old 10-01-2009, 02:21 PM   #10 (permalink)
SRT of the Month
ERABBIT23's Avatar
Member Number: 39786
Trader Rating: (56)
and turn up the boost
Worlds Fastest 5 Speed NSRT-4 ET and MPH
Only SRT-4 Trapping 150+ Without Nitrous
Built and Tuned by Realtune Powered by AGP Turbo and Cylinder Head by Darrel Cox Racing
Check Out ERABBIT23 on Youtube 4 Videos!
ERABBIT23 is offline   Reply With Quote
Old 10-01-2009, 02:31 PM   #11 (permalink)
d_fl8ted1's Avatar
Trader Rating: (81)
that is my other plans i am going to crank up the boost on pump gas if i can keep the knock down and lower the timing... i am going to try to get the number 3 spot on the dcr times list... for the autos... which will be in the
6.80s i want to do it without spraying out of the hole... but i may have to but we will see...
The next thing is trying to figure out if i need to use the two step function with the auto
Old 10-01-2009, 09:04 PM   #12 (permalink)
nutz's Avatar
Trader Rating: (19)
it may build boost alot faster so watch timing, I wish I had an auto
Old 10-01-2009, 09:06 PM   #13 (permalink)
nutz's Avatar
Trader Rating: (19)
sure just set it for the stall speed, it would be bad ass with a break. the speed based will work (always 2 steping below xx mph)
Old 10-02-2009, 07:34 AM   #14 (permalink)
d_fl8ted1's Avatar
Trader Rating: (81)
Yeah i know i wish i had a trans brake but darrell said it is very hard on the transmissions so i wanted longevity as much as i could... so if all else fails i will spray it out of the whole...
So i will set the two step to say 3800 rpms and have it shutdown at lets say 2 mph off the line... or should i set that to 0..
I am also going to try to set this up as a boost by rpm setup... that way first gear will boost only wastegate and then 20 in 2nd and 25 in 3rd but i am confused on how to manage that... seeing i see the boost line graph and then the wastegate duty cylce
Old 10-02-2009, 05:06 PM   #15 (permalink)
nutz's Avatar
Trader Rating: (19)
yea a brake heats up the tranny in no time, i would set the 2 step for 5mph to start (and adjust as needed), I dont know much about the boost controler settings with the EMS, I would love a tutorial on that subject too. I hope Jay or aaron chimes in (N2MB FTW)
Page generated in 0.14713 seconds with 13 queries
