Old 05-11-2009, 11:44 PM   #16 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
Ok, one quick thing. How did you set up your TPS calibration? If you simply went through the auto-calibration for the TPS and didn't adjust the min voltage afterward, that would have a lot to do with your feedback controls working to stabilize your idle.
I feel it's a fluke with the AEM software, but the ignition and fuel trims for idle stabilizing will NOT act unless your reading greater than 0% idle. What you need to do is auto-calibrate your TPS, then after completing that process, you need to go to [SETUP] [SENSORS] [THROTTLE POSITION SENSOR] [OPTIONS - TPS], and from there, decrease the minimum voltage value so that your idle percentage reading while not pressing the gas at all is reading greater than 0%.
After doing that, your ignition and fuel trims for idle stabilizing will begin to act.
Now, as Nutz mentioned, you NEED to make sure the fuel map is as close as possible. the fuel/ignition trims should not be 100% depended upon to keep your car running "ok".
Before knowing about this issue with the TPS voltage/% correlation, I still managed to get my car to idle steady with 1000cc injectors w/out the aid of the Idle fuel/ignition trims.
MY FAVORITE EQUATIONS:
Fuel Volume = (HP * BSFC) / (# of injectors * IDC)
CFM = C.I.D. * RPM * V.E. *.5 / 1728
P.R. = (PSI Boost + 14.7) / 14.7
HP = TQ * RPM / 5252
Old 05-11-2009, 11:51 PM   #17 (permalink)
Now, on to the reason I feel that this is a fluke with the AEM software.
When doing this (adjusting TPS voltage/% correlation), your "O2 FB DFCO Clear" never works. What this means, is that when you are cruising, if your O2 feedback is acting and reaches a -7% or greater value, when you let off the gas afterward and go back to idle, your car will stumble for a minute, because the O2 feedback is still trimming -7% or greater from while you were on the gas. And at idle, that will usually be enough to cause a pretty nasty stumble, and sometimes a stall.
Again, this pretty much goes back to having your fuel map as well dialed in as possible so that O2 feedback doesn't have to work too much.
Old 05-12-2009, 12:18 AM   #18 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
chuck
how much for you to bless my stock bottom end
Old 05-12-2009, 12:27 AM   #19 (permalink)
Quote: Originally Posted by nutz View Post
chuck
A round trip plane ticket, room and board, and 3 square meals a day!
Just don't allow me to get too crazy with it, or you'll suffer the same fate I did...LOL!
Old 05-13-2009, 08:59 AM   #20 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
i absolutely agree to agree with the above forementioned mention indubebably
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 05-13-2009, 09:04 AM   #21 (permalink)
Whoa, Jay! You've got my head spinning with that one!
Old 05-13-2009, 09:10 AM   #22 (permalink)
Trader Rating: (59)
Old 05-28-2009, 08:17 PM   #23 (permalink)
Member Number: 42803
Default Idle
did ou get your Idle fix and if so what did you do?
Mods:
Mopar Stage 3
F&F 47LB Wheel and port
Mopar Short Throw shifter
Mopar Down Pipe
Mopar Exhaust
Avid Motor mounts
AEM EMS
Apex Turbo Timer
AEM Wide Band
BWoody Traction Control Bars
MPX Large Front Intercooler
AGP AGP Wastegate Actuator
Exhaust Depot Hardpipe Kit
HKS Super Sequential Blow-Off Valve
ClutchMasters 650
ehr242 is offline   Reply With Quote
Old 05-29-2009, 06:40 PM   #24 (permalink)
Member Number: 64986
Yea, sorry. April 5th is the start of gasoline blending season, so i've been... hectic, to say the least. As well, I got my promotion, so visited my private life.
It was fixed in the fuel enrichment table, as well as replacing the broken IAT sensor (the new helped only a very little with the idle). I have some more tuning to do, but it isn't going to be daily driven more then a mile to and from work until I get my secondary car. At that point, I will have a 3582 put on it and we'll go from there with the tuning
Thanks for all of the advice
demens is offline   Reply With Quote
Old 10-29-2009, 01:43 AM   #25 (permalink)
Member Number: 75888
Plz! I need help with calibration settings on my 05 neon srt 4? I just installed a new throttle body that is a little bigger and now a check engine light is on about my tps sensor! What do I do???
Nielseet25 is offline   Reply With Quote
Old 10-29-2009, 01:49 AM   #26 (permalink)
nutz's Avatar
Trader Rating: (19)
post in a the proper section
Page generated in 0.39527 seconds with 14 queries
