Quote: Originally Posted by
Dasstrum
Well, the one I loaded was one of the Configs that came with the software for the gauge. I loaded the "BASE CAL AEM 3.5 bar" file. I do have the stage 2 MAP in the car which I think is a 3 bar, but I don't think that would matter. The only thing it does in the program I think is set the "High Alarm" to 35.3psi default instead of 15.3psi in "High Alarm" if I loaded the "BASE CAL AEM 2 bar".
As far as I know, in the program, does it matter if its set up to 3.5 bar map if I am running a 3 bar map? Boost is Boost right, that .5 more on the MAP just means it can read a higher amount of boost right?
Not exactly. I think that's your problem, right there! If you have the serial data guage calibrated for a 3.5 bar sensor, and the AEM calibrated for a Mopar 3 bar sensor, there is going to be an obvious discrepancy between them.
Both the Mopar 3 bar and AEM 3.5 bar sensors work off of a 0 - 5 Volt scale, and interpret the voltages as x psi/volt.
For example, here's the scale for the AEM 3.5 bar map sensor:
Volts: 0.5 -- 1.0 -- 1.5 -- 2.0 -- 2.5 -- 3.0 -- 3.5 -- 4.0 -- 4.5
PSI: -14.7; -8.45; -2.2; 4.05; 10.3; 16.55; 22.8; 29.05; 35.30
And here's the scale for the Mopar 3 bar map sensor (starting from 1.5 volts, as I don't have the full scale in front of me):
Volts: 1.5 -- 2.0 -- 2.5 -- 3.0 -- 3.5 -- 4.0 -- 4.5
PSI: -1.30; 3.00; 7.80; 12.00; 16.90; 21.00; 25.50
You need to have the AEM serial data gauge calibrated to the same sensor you're using.
