Old 06-19-2008, 08:47 AM   #16 (permalink)
d_fl8ted1's Avatar
Member Number: 11549
Trader Rating: (29)
ok we are workign on tuning and going to do a good road tune on it saturday but i have some more questions...
First my tuner wants to turn off the 02 feebback when in boost is this a good idea. He wants to run it off the fuel map instead of trusting the o2?
Second any pointers on the boost control will be great.... I have the aem solenoid to manage boost but we just need some pointers setting it up to a run through..
Thank you
"When the turbo spins, the bullshit ends"
d_fl8ted1 is offline   Reply With Quote
Old 06-19-2008, 03:15 PM   #17 (permalink)
lilmike0450's Avatar
Member Number: 56278
yes turn 02fb off in boost....
05 White ACR
lilmike0450 is offline   Reply With Quote
Old 06-19-2008, 03:27 PM   #18 (permalink)
d_fl8ted1's Avatar
Trader Rating: (29)
ok will do that...
any pointers on boost control... do i want to use rpm based boost
where would be a good place to start on wastegate duty percentage..
Old 06-19-2008, 03:42 PM   #19 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (391)
Thank you
Im confused. You have a ''tuner'' but he doesnt know how to set up/cal the wideband or the boost solenoid?
I can see this getting very ugly pretty quick
10.62@133.8 '05 SRT-4 Neon
11.87@125 '08 SRT-4 Caliber
Worlds Quickest/Fastest CSRT-4
Old 06-19-2008, 03:43 PM   #20 (permalink)
Member Number: 623
Depends.
I sometimes leave the feedback on and sometimes have it shut off around 5-6psi.
Just depends on whats going on with the car/setup
Old 06-20-2008, 06:06 AM   #21 (permalink)
My o2 is off after 7 or 9lbs. i cant remember which....I also use VSS Boost. I agree will Aaron, you tuner should know all this. well with your WG duty % it depends on your setup. 0.00%(if your WG is not inverted) is your WG spring, so whatever spring you have in your wastegate is how many lbs that will be. Make sure that Boost WG output is checked. If you dont use a Boost target method(vss,rpm/tps) then Boost By Load needs to be checked. WOW....PM me
Old 06-22-2008, 06:40 AM   #22 (permalink)
d_fl8ted1's Avatar
Trader Rating: (29)
the guy i have helping me on my aem tuning is a well known tuner around my area but mostly with hondata and chrome software.... we together have never installed or messed with the aem.. so this was a learning experience..
as for going bad .... the car now runs on twenty psi of boost with the o2 shutting down at 2 psi... and running 11.4 afrs and 12 degrees of timing at 7000 rpms with absolutely no knock....
Old 06-22-2008, 06:45 AM   #23 (permalink)
d_fl8ted1's Avatar
Trader Rating: (29)
I will have to go in my tune and check on how he set up the boost for sure.... but i know it comes on with rpm... till it hits 20 psi... i think my wg percentage is at around 50%..... I figure with the gt40 that is pretty good spooling full boost at 4800.... The car never seems to stop pulling... I can roll out in second and nail it and the tire spin is non existant due to the spool coming on the way it does...
I am sorry guys if i am asking dumb uestions.... just trying to learn... if you feel my boost is setup wrong please let me know... or if you have any tricks to making the boost come on faster...
Old 06-22-2008, 06:47 AM   #24 (permalink)
DJOrtiz's Avatar
Member Number: 17860
Trader Rating: (20)
well thats pretty good headway from the time you started this thread...
100KB size limit, not 1.6MB.
DJOrtiz is offline   Reply With Quote
Old 06-22-2008, 06:51 AM   #25 (permalink)
d_fl8ted1's Avatar
Trader Rating: (29)
Thanks yes we have learned alot this week... still have some issues with my idle jumping around but i think my iac valve might be dirty... going to take it out and clean it and see if it helps out...
But other then that the car is running strong and the two step sounds trememndous.... We have it set to build 10 psi in less then two seconds....
Old 06-22-2008, 06:57 AM   #26 (permalink)
DJOrtiz's Avatar
Trader Rating: (20)
*whistles* nice... yeah i run the DTEC FBC and i notice some similarities with the boost threshold... i had mine set to 85% and i had hella fast spool up, but then again these to systems can be structured differently... i'm running 50trim DBB...
Old 06-22-2008, 07:10 AM   #27 (permalink)
d_fl8ted1's Avatar
Trader Rating: (29)
I wouldnt mind having alittle faster spool up... but we will work on that after pinks....
We had mine set at 65% and it boost about 24 psi.... so we had to turn it down to accomplish the right boost.... Like i said guys still learning...
I wish lilmike would pm me and i would just give him my number to call me and walk me through this lol...
I will have the file on my laptop today and look over the boost settings and post them up
Old 06-22-2008, 08:57 PM   #28 (permalink)
I sent you a pm.....
Old 07-05-2008, 07:11 PM   #29 (permalink)
d_fl8ted1's Avatar
Trader Rating: (29)
i got your pm lilmike and thanks for the number but i have been swamped and realized that after pinks last weekend my car was no where near where it needed to be.... so to solve this.. .i will be calling AMS monday to setup an appointment to get my car tuned....
Old 07-06-2008, 05:59 AM   #30 (permalink)
^^^good idea.
