ok, well can anyone shed light on how to do this. I was talking to a tuner and the topic came up, when i search the power forum i find its very important to do (idle and throttle response drivability) i guess when i changed my mb/sec and boost fuel correction i threw it outa wack + my cam is much larger than stock, this is new to me as i was under the impression the EMS di it on it own
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4 DSP or Trinity
For all other questions send them to ptperformance@comcast.net For SoCal guys only! Now offering JD-M Specials!
lol, I have seen about 100 srt maps and noone does this, after speaking to an engineer I find it one of the most important and overlooked tables on the EMS, I was under the impression it was done for ya untill today
well i have it sold, so i hope i dont need to come back.
wish me luck
lol, dude you'll be fine I'm pretty sure your in good hands
the EMS is a pita anyways, every time i think I have a hold of stuff POP up comes something new, thank god Chuck has been kind enough to guide along these past couple days I think some very new and exciting things are in the EMS's future
learning something new every day
man nuts, you're always jacking around with something aren't you?
Its very important to have right for part thottle fueling when using sequential injection. Since the injectors are open nearly the whole time during WOT(+600 crank degrees. note: the intake valve is only open for around 230-250), its not critical when they actually start.
If your not having issues with part throttle drivability, leave it alone.
Note:
older batch fire injection, like on my duster, runs the injectors constantly so there is no such thing as "injector phasing". They never stop firing. The fuel just sits behind the valve until it opens. Works perfectly fine. This was OEM standard for TBI and MPI until tighter emmissions regulation dictated a switch to sequential, because part throttle fuel control was more precise.
i want it perfect, i mean if my injectors are out of phase or off a bit I should just switch to a batch fire set up. I found a few how to's on the aempower site along with some spread sheets. if i ever figure out how to use em i will post up results
on an srt4 there is no reason to mess with injector phasing. the only reason why you would want to venture in that neighborhood that i can think of is if you are not running an iac motor and you have ginormous cams and you have a bad lean tip in or puddling fuel on the intake valves(cant see that happening though unless you went with a smaller duration cam)
the sled is tuned like that because it doesnt have an iac and it has big cams.
all injector phasing is doing is either retarding or advancing the injector opening in relation to tdc.if you feel the need to mess with it you can force it to idle rpm with no feedback and advance phasing until you peak rpm then drop off.thats about the right spot for advance but keep changes very very small and do yourself a favor and save your map before you screw it up and dont have a turning back point
Email: Jay@N2MB.com
5/24/09 9.30@154
I thought this is what the USEC and Deadtimes were for? Once you have that info for your injectors the phasing should fall in line, correct?
Maybe I'm mis-understanding.
Here is an example of what numbers I'm talking about. These are Injector Dynamics 1000CC's for an EVO IX. Mine are the same, just less junk in the packaging cause they were plug and play.
naa, it has to do with syncing up the intake valve opening to the injector fireing, for some reason if you use the boost correction tables (multiple of base numbers) it screws up this sync pretty bad
IE: if the EMS sees a 4.2us pw but with the boost correction that is only 1.8us it will only sync the number from the map (not the corrected value) so some of your fuel is being shot AFTER the valve is closed and that makes for a delayed reaction and all around shitty performance (from idle to about 3k rpms) it is still syncing to the front of 4.2us
I can change my maps to a hybred boost comp and low load drivability would be much better
so the moral of the story is..... full boost comp while being easier to build/tune will require an advanced understanding of injector phaseing, I had the privladge of looking at an engineers map and their phase tables are very very well done
