Quote: Originally Posted by
nutz
the how too is in the sticky, if you have a 1510u and want to hook up second wideband i am not sure if you would use #1 or #2 cause i dont know what the ecu's input is
Here is the instructions but it says to a non uego ems.... I have the 1510
U witch already has wideband in it... all I want to know it how to view the reading on my gauge... All i have is the gauge purchased from aem... it is not a uego wideband just a gauge.
Thanks
Uego gauge to
Non uego EMS
How 2:
1]Take the White wire coming off your AEM Gauge.
2]Run the white wire down by the Factory PCM.
3]Open the harness of the Orange PCM. Locate the Black wire with dark green stripe. C2-31 is the location if you need it.
4]What I did was cut the black/green wire in half. Connect the PCM side of the wire to the white wire coming from you AEM gauge. Soder and retape the harness[plug back into PCM]
5]Go to Setup/Sensors/O2#1/02 wizard... select AEM Gauge
6]Then check out the volts that the EMS is seeing and make sure they match up to your AEM gauge. You can adjust the gain by Selecting Setup/Sensors/O2#1/options. You can check the volts by selecting Setup/Sensors/O2#1/parameters.
Dont forget to change the cal table from METH to Gasoline a/f. Do this by going to Configure/Units/A-F units/ Af gasoline
