Old 05-08-2008, 07:01 PM   #1 (permalink)
Member Number: 37663
Default Help!!! Problems with wideband on AEM EMS UEGO
Okay here is the run down. We installed the AEM EMS UEGO and it reads 3.94v (which is correct) with the sensor disconnected. However, as soon as we plug in the sensor it reads 5v with the key turned (should be 14.0) and reads the same when the car is running. When we give the car some gas the a/fs stay right on 8.1 and 5v. Any ideas or suggestions on what's wrong?
MISCHIEF is offline   Reply With Quote
Old 05-08-2008, 07:09 PM   #2 (permalink)
lilmike0450's Avatar
Member Number: 56278
The lowest that wideband shows is 10 flat so where you getting an 8.1 from...
05 White ACR
lilmike0450 is offline   Reply With Quote
Old 05-08-2008, 07:14 PM   #3 (permalink)
Oh did you adjust your O2 gain??
Old 05-08-2008, 07:56 PM   #4 (permalink)
Figured it out. Even though "gasoline" is selected the EMS can still default to "methanol" but show "gasoline" selected. In order to fix the problem, you have to select another fuel then reselect gasoline
Old 05-08-2008, 08:06 PM   #5 (permalink)
so what does it show now??
Page generated in 0.17226 seconds with 11 queries
