Old 03-20-2009, 08:41 PM   #1 (permalink)
Member Number: 27506
Default EMS issue...
Whenever I tap the EMS ecu it shuts off the car...
As you can image when I go over bumps the same happens.
Is something not hooked up? Or should I just send the box back?
Thanks
DGR8srt is offline   Reply With Quote
Old 03-20-2009, 08:56 PM   #2 (permalink)
d_fl8ted1's Avatar
Member Number: 11549
Trader Rating: (81)
hmmm very interesting....
make sure all the clips are in there good and check all pinouts and make sure they have good connections..
On the 8th day GOD created drag racing
d_fl8ted1 is offline   Reply With Quote
Old 03-20-2009, 09:03 PM   #3 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
Thanks
if you use the stock ECU (i know it wont run rite) and it still does it i would imagine its in the wireing, if it stops its in the EMS
Old 03-20-2009, 09:12 PM   #4 (permalink)
d_fl8ted1's Avatar
Trader Rating: (81)
yeah didnt think of that...switch the factory ecu back in and see what happens..
Old 03-20-2009, 09:28 PM   #5 (permalink)
Gonna try the swap in the morning.
Man i tried all sorts of shit too wiring seems fine...tired adding an additional ground point and thats when i found out it was the EMS the wrench dropped on it.
I didnt think it would start with the stocker...thanks
Keep the suggestions coming
Old 03-20-2009, 09:32 PM   #6 (permalink)
d_fl8ted1's Avatar
Trader Rating: (81)
yes it will start... i drove mine down the road on my stocker... when i was having issues...
Old 03-24-2009, 12:17 AM   #7 (permalink)
nutz's Avatar
Trader Rating: (19)
any up date bro
Old 03-24-2009, 08:04 AM   #8 (permalink)
lilmike0450's Avatar
Member Number: 56278
Trader Rating: (10)
Bump...
Quote: Originally Posted by 91PumpKing. View Post
i promise i am after this motor goes in.
things that arae bought down the road will just be maintenance/replacement related.
lilmike0450 is offline   Reply With Quote
Old 04-07-2009, 07:43 PM   #9 (permalink)
Sorry I live in the caribbean it takes awhile for things to go back and forth.
Thanks to everyone for their suggestions!
Sent the EMS to AEM who stated they saw nothing wrong and only needed to update the wideband software...
Just came inside from installing it and so far after the tests (banging it) it works without shutting off.
NOTHING was changed on the car but the AEM leaving and returning...
I will fully install it and go for a test run tomorrow.
Can't wait for my parts install and retune to go get back my track record
Page generated in 0.15361 seconds with 13 queries
