Old 07-19-2008, 10:38 AM   #1 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (46)
Default EMS hook up trouble(pics)
I have read Fraziers thread and the Sticky, still no help. I need to connect and change a tune on my ems. Im follwing Aarons step by step:
Re boot comp
Plug in cord
Click AEM software
Turn key(wait second)
Hit connect
And then immediatly I see this:
So......This is my cable:
Then, hook it in and hit AEM software:
Hit connect:
Check my conection type:
How do I get my comp to recognize this USB connector? I tried downloading shit from the internet, no work. Tried the auto updates on comp, no work. Tried on 2 different lap tops, no work. So is there another usb connector type than this one(from best buy, like 15 bucks i think)....
SARCASTIC.
FS: O2 housings(stock/stage 3), stock IC(s), Autometer Wideband (ultralite pro comp $330 gauge), 49lb Ported FnF Stg 3 Big wheel with 3.5" O2 and AGP WGA(CHEAP)...PM for offers
Old 07-19-2008, 10:51 AM   #2 (permalink)
littlepvt's Avatar
Member Number: 3267
Trader Rating: (45)
you need to select serial then select the virtual com port that it is using
DCR: 2.6 over 40 stroker, Pro series Head w/ Crane 18, Input Shaft, Intake manifold w/ Tial BOV, CP Ignition
AGP: GT3582R turbo kit
Mopar: Sway Bars, S3R CO, Ti Strut Bars,
Rage-Tek: LCA, TOB, Triple Fuel Pumps, 1000cc Inj 3/4 fork
Autometer: WB, Boost, Oil PSI, Oil Temp, EGT, FP
ClutchMaster: Twin Disk
AEM: EMS w/ 3.5 BAR sensor
JMB: 4in Intake, Hotside Hardpipe
Boomba: All 3 MM
littlepvt is offline   Reply With Quote
Old 07-19-2008, 10:59 AM   #3 (permalink)
SRTforums Veteran²
onthedwnlow's Avatar
Member Number: 27125
Trader Rating: (46)
you need to also hit connect then turn key on.......not vise versa
sorry guys but the car is for sale....all out first gen is in the works
onthedwnlow is offline   Reply With Quote
Old 07-19-2008, 11:02 AM   #4 (permalink)
Member Number: 18856
this is how i run mine
plug usb into port on laptop(ig off laptop on and fully booted)
click AEM pro should automatically allow you to select port under usb
click connect (should say ECU OFFline)
Key ig on at this point
not a thing just another slow ass neon
joe smalls is offline   Reply With Quote
Old 07-19-2008, 01:54 PM   #5 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (47)
keyspan usa-19hs /thread
Email: Jay@N2MB.com
take a moment today to reflect on what happened on 11 september 2001...
Old 07-19-2008, 03:39 PM   #6 (permalink)
Trader Rating: (46)
please excuse my rather "noob-ness" but what the fuck does that mean? Is that a drop down inthe AEM software menu? I need to buy that somewhere?
When im at the serial or usb screen and hit the drop down nothing shows....do i need to manually write something in there?
Old 07-19-2008, 03:43 PM   #7 (permalink)
Member Number: 19053
Ok I think I can remember the sequence. If it does that turn key off unplug usb cord close aem pro. Plug in usb open aem pro turn key on click connect. If it does not reconize the usb like you posted you may have to try another port.
ghost-1 is online now   Reply With Quote
Old 07-19-2008, 07:33 PM   #8 (permalink)
Member Number: 41218
that keyspan thing on his post is a connection cable that uses a usb to 9pin connector, that you purchase, which is better for connection purposes. the black plastic connector that aem has,is not really goo(i have heard). i hard wired the wires that connect inside the plastic piece, directly to the odb connector under the drivers side(you should know what i am talking about.then after i bought the keyspan cable, i could not connect(i have vista)until i downloaded the updated software from the keyspan website. it all sounds crazy, but to be sure to always connect, i did it that way. it is quite possible that aem has worked on the connection issue and you may be able to connect eventually.
reysrt4 is offline   Reply With Quote
Old 07-20-2008, 04:36 PM   #9 (permalink)
Trader Rating: (47)
this is what i meant
here are some links where you can buy it
Walmart.com: Keyspan High-Speed USB/Serial Adapter, USA-19HS: Computers
Amazon.com: Keyspan High Speed USB Serial Adapter ( USA-19HS ): Electronics
Keyspan High Speed USB Serial Adapter - USA-19HS - Buy.com
here is where you can download the most up to date drivers for it
Keyspan | Downloads | Select Your OS
thats is the most reliable usb to serial adapter i have found.i have used it to connect to tons of cars without any problems
Old 07-20-2008, 04:41 PM   #10 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (398)
Hit up radio shack and pick up their usb/serial converter. Thats what I use on both of my lap tops.
It looks like your EMS is not even seeing your port though. So your cable might actually be fine
10.62@133.8 '05 SRT-4 Neon
11.74@120 '08 SRT-4 Caliber
Worlds Quickest/Fastest CSRT-4
Old 07-20-2008, 04:43 PM   #11 (permalink)
I would not trust this guy
Old 07-21-2008, 01:14 PM   #12 (permalink)
Member Number: 41700
lol, did you install the drivers for the adaptor ?
Old 07-26-2008, 09:36 AM   #13 (permalink)
Trader Rating: (46)
buying today, thank you for the info jay and everyone else...
This seems like a stupid (easy) but stupid problem for a handfull of new EMS users. Its a 1900-2200 system, why the fuck cant this thing connect easier/better....
Oh well, im a buy this today and give it a shot. Thanks again
Old 07-26-2008, 09:39 AM   #14 (permalink)
Trader Rating: (47)
no problem, if you are still having problems shoot me a pm with your number and ill try to get you up and running on the phone
Old 08-09-2008, 05:16 PM   #15 (permalink)
Trader Rating: (46)
ok, well i got the keyspan and now i can connect and get into the software but how do i change tunes? I was sent a updated tune from aaron via email and i saved it and now it seems like the ems doesnt recognize it anywere...
I looked arround for another post about this, maybe i missed it in the stickys....where should i go to "re flash" or change to one of my other tunes?
