Old 04-19-2009, 09:20 AM   #1 (permalink)
Member Number: 42667
Default EMS controlled water injection
Is there any way that the EMS can control water injection so that I can use the nitrous map to add ignition timing? Also, is there a way that you can use the level sensor in the tank to shut the nitrous map off when you run low on fluid (use the level sensor as the arming switch?)
Since 99% of the water injection systems us a variable displacement pump, can the EMS control that? Or can it only do a "pump on/pump off"
I want to buy a water injection kit but dont want any more controllers, modules, wiring, etc etc etc in the car. I would prefer to let the EMS do it all.
Is there a specific kit that anyone can think of that will let me do what i want to do?
AEM recently came out with their own water injection and i assumed they'd come out with one made specifically for people with an EMS...I guess i was wrong.
05plsrt4 is offline   Reply With Quote
Old 04-19-2009, 10:21 AM   #2 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
there is a user controlled PWM out put but you need to assign an x and y axis. i am assuming some type super relay would be needed
it is in the setup drop down when i get home i will pull the instructions...i think its a great idea keep us all posted on ANY developments
Old 04-19-2009, 10:51 AM   #3 (permalink)
turbojack's Avatar
Member Number: 11814
Trader Rating: (122)
The AEM W/A kit or any other very basic W/A kit will integrate into the EMS using the nitrous mapping. This enables very simple W/A trigger and controlling = wiring is easy, but its not that accurate in control. Nitrous control even progressive is usually just a window to operate within and its on and off = all or nothing.
IMO if you have an AEM EMS make your own W/A kit and save a bundle. Buy just the hardware you need as an AEM kit to used with the AEM EMS in this instance offers nothing as you are paying for the brand not hardware. Look close at using the nitrous mapping in the directions and then what is contained in an AEM W/A kit and you will see that you do not need very much in hardware. Again, its makes for a simple W/A setup but it also does not offer much other then the simplicity.
Old 04-19-2009, 11:03 AM   #4 (permalink)
Ok, but assuming the engine will require different W/A amounts at 5 psi compared to 25PSI, how do you control that with the EMS? Can you integrate the user programable PW map and the Nitrous map together?
Old 04-19-2009, 12:48 PM   #5 (permalink)
nutz's Avatar
Trader Rating: (19)
dont quote me, but look into the secondary injector circuit it is capabul of amazing things and can pick up where the injectors leave off BUT actual injectors (like the hahn system) and a constant on fuel pump would be needed (fuel cell with dedicated pump) this was in the works but scrapped due to an A$$ hole (and my lack of any funding) ....this will be expensive but would allow O2 feed back
edited: almost let the cat out
Old 04-19-2009, 01:04 PM   #6 (permalink)
OrAnGe-SrT4's Avatar
Member Number: 29828
Trader Rating: (30)
Quote: Originally Posted by never2muchboost View Post
thats easy, wire up a relay and have the relay ground controlled by the ems.for example you can wire it up like this
ground the pump to chassis ground.run the b+ out of the relay to the pump.on the coil side of the relay run your 12v in and run the ground to low side driver #ls3 in the ems (just as an example)
next you go into the ems and click options>configure outputs
on the drop down menu selct ls5 and check basic activation.
if you want the w/i to come on at say 12 psi you want the basic activation to look something like this
coolant temp/at least 160*
load/at least 12 psi
rpm at least 3000
tps at least 80%
road speed at least 20 mph
that will make it work but i would suggest putting a switch on it as well for activation.to do that you click switched ouput configuration and setup the switch parameters for however you wire it up
EDIT: WHEN YOU USE AEM LOW AND HIGH SIDE DRIVERS DO NOT USE LS OR HS 1-4. USE 5-8 EITHER HIGH OR LOW.THE REASON WHY IS WHEN YOU KEY ON THOSE DRIVERS WILL PULSE FOR A SECOND. YOU DO NOT WANT YOUR NITROUS OR METH SPRAYING WHEN YOU KEY IT ON!!
Quoted from N2MB
OrAnGe-SrT4 is offline   Reply With Quote
Old 04-19-2009, 04:29 PM   #7 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
yes you cn do it like that.you will have to wire in an extra relay into the power wire for the pump. what it the level sensor output? 12v? if it is then you can take the power wire and cut it put the power to pin 87 and the other side to pin 87a so that when the relay isnt energized power will flow through 87 to 87a .on the coil side of the relay run pin 85 to ground and the 12v from the level sensor to pin 86. when the level sensor comes on it will actuate the coil side and switch the relay ouput to pin 30 which in this case would cause an open circuit and the pump wont come on.
actually now that im thinking about it you may want to actually run a wire from pin 30 to the switch input for the nitrous map so that it wont enable the nitrous map as well. you really dont want more timing if the pump isnt on
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 04-19-2009, 05:25 PM   #8 (permalink)
nutz's Avatar
Trader Rating: (19)
would it be possible to make the EMS a variable controller (pulse with modulated) to the pump and use boost, o2 or tps as the X, Y
Old 04-19-2009, 10:15 PM   #9 (permalink)
Trader Rating: (59)
nope,theres no progressive control
Old 04-20-2009, 02:08 AM   #10 (permalink)
nutz's Avatar
Trader Rating: (19)
Old 04-20-2009, 06:58 PM   #11 (permalink)
Well thats a little depressing!
So i take it that means that the user programable PWM cant be tied into the nitrous map in any way?
Old 04-21-2009, 12:04 AM   #12 (permalink)
nutz's Avatar
Trader Rating: (19)
were you trying to make a progressive N2O controller
i would think there is a way BUT you may need to be the guy who figures it out <3
i looked in the manual (nothing) and on the AEMPOWER forums many questions avbout using that table for a progressive controller but no answers
i think you would need to know the max-min freq for the amount of flow or use a water/meth solenoid to control the PW
Old 04-21-2009, 07:01 AM   #13 (permalink)
turbojack's Avatar
The way to best do this in my opinion would be to have the EMS control a 5th injector. The 5th injector would be for W/A injection. But an issue is that the AEM EMS does not really have anything in it for tying in a flow sensor.
The Hydra EMS has done this but sadly Hydra did not do a very good job in how they went about releasing the their EMS for the SRT-4 so everyone buys the AEM and nearly anyone runs the Hydra on the SRT-4. Look for Hydramist on the NASIOC site in the forum dealing with W/A injection so see how a water injection system can be integrated into an EMS.
Old 04-21-2009, 05:08 PM   #14 (permalink)
ge_forcez22's Avatar
Member Number: 59151
do a quick search on FJO water injection setups. They basically use a pulsing nitous solenoid for injection.
FJO Racing Products - Water/Methanol Injection System
you could likely use a nozzle like that and just feed it a pulsed source.
-Garrett
2004 - SRT4 -Wiseco pistons -Crower rods -Port/Polished head -DCR 272/272 -AEM EMS -RC750 -SMC Watermeth -BFMIC -AGP 60-1 -AGP return line kit -3" MPX with single exit -Eibach Springs - Tokico suspension -ACT 6-puck -DSS stage3 axles -MH 24.5x8.5
-424whp @ 26psi
-12.0 @117mph @ 23psi
ge_forcez22 is online now   Reply With Quote
Old 04-21-2009, 05:51 PM   #15 (permalink)
I've read somewhere that people were using a pump that runs 100% duty cycle and then using a PW solenoid hooked up to the variable valve timing tables to pulse the proper amount of water into the intake.
Does that make any sense?
Page generated in 0.22541 seconds with 13 queries
