Old 08-28-2006, 09:43 PM   #1 (permalink)
Tex
Tex's Avatar
Member Number: 3622
Default EMS cable fix...fast, cheap, and easy
if you can solder then order this
http://www.obd2cables.com/products/p...products_id=44
if you cant you will need this list:
1 of http://www.obd2cables.com/products/p...products_id=49
4 of http://www.obd2cables.com/products/p...products_id=50
1 of http://www.obd2cables.com/products/p...products_id=55
either way it will set you back less than $20 and you should have them in 2-3 days
its what i did and it ROCKS!!!!!
you will have to tear the plastic cover off of the one aem sends you. find the 4 wires and reattach them in the right place.
connect the red jumper lead to the bottom #5 from teh left (when looking at the connector like in the pic
connect the reds to top #3
connect the white to top #2
and connect the black to top #5
easy as pie
-Soren Kierkegaard
Tex is offline   Reply With Quote
Old 09-25-2006, 06:47 PM   #2 (permalink)
AWD_THIS's Avatar
Member Number: 6481
easy as pie
It didnt work Tex.
AWD_THIS is offline   Reply With Quote
Old 09-25-2006, 07:47 PM   #3 (permalink)
RoostBoost's Avatar
Member Number: 7368
Trader Rating: (72)
what's wrong w/the EMS cable?
RoostBoost is offline   Reply With Quote
Old 09-25-2006, 08:42 PM   #4 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (43)
hey tex are you sure about that pinout?
Email: Jay@N2MBRacing.com
Old 09-25-2006, 08:44 PM   #5 (permalink)
Tex
Tex's Avatar
Member Number: 3622
i am 100% sure, but i got a pm asking about it. mine works wonderfully, so i might have screwed somthing up in translation. i will check tomarrow after class and verify.
Old 09-26-2006, 08:13 PM   #6 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
I just take the covers off so that they set all the way in... I also remove the factory plug from it's mount and zip tie them together..
I suppose you could just cut the connector off and splice the wires in back of the stock connector and leave it hard wired.. I've done that too..
NemoFoss is online now   Reply With Quote
Old 09-26-2006, 08:35 PM   #7 (permalink)
AWD_THIS's Avatar
Member Number: 6481
when you talk about hard wired do you know which cables goes where
Old 09-26-2006, 09:05 PM   #8 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
I do but will have to look that up at the shop..
Old 09-26-2006, 09:06 PM   #9 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
you basicly wire it to same wires that would touch if you plugged in the connector
Old 09-26-2006, 09:57 PM   #10 (permalink)
Tex
Tex's Avatar
Member Number: 3622
guys, im quite sure that the pinnouts are correct. i verified just a minute ago. mine works wonderfully. again the red coming out of the cable top#3 from the left, like at the pic above. white is top #2, black is top #5 and the red jumper goes from top #3 to bottom #5. if it doesnt work, i dont know what ot tell you. mine works just fine and thats how its wired in.
if its not working, its not hard to figure out. look at the connectors, and match with what color wires go where
Old 09-26-2006, 10:47 PM   #11 (permalink)
RoostBoost's Avatar
Member Number: 7368
Trader Rating: (72)
sorry, but i don't understand why you would want to do this?
please explain...
Old 09-27-2006, 07:54 AM   #12 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
because aem cables suck.. and lose connection often..
Old 09-27-2006, 09:29 AM   #13 (permalink)
RoostBoost's Avatar
Member Number: 7368
Trader Rating: (72)
thankyou....I will try the fix as well
thanks guys!!
Old 09-27-2006, 11:08 AM   #14 (permalink)
distinctdev's Avatar
Member Number: 22976
Trader Rating: (32)
i was thinking about soldering in a db9 serial port and then just using a serial extension cable instead of aems cable all together eliminting the obd2 part
R.I.P. Steven Lorenz 04.04.06
MySlips.com
Bench Racing Stops Here.
distinctdev is offline   Reply With Quote
Old 10-01-2006, 07:13 AM   #15 (permalink)
Trader Rating: (43)
interesting thing i found now,i fixed my cable and i can log everything so i tried my cable on another one and it didnt work..really damn weird
