Has anyone used the autometer WB and the ems? I'm having trouble getting the Ems to read the same voltage as the gauge. I do know that the Autometer WB only has a range of 0-4v so what I did was program the gauge to have a scale of 10.0-18.0afr. This keeps me in the same linear range as a 0-5v gauge. Only problem is when the car is running the laptop reads a point higher than the gauge. I have tried using the o2 wizard and tried different brands of 02 sensor but nothing changes. Any ideas?
DCR: 2.6 over 40 stroker, Pro series Head w/ Crane 18, Input Shaft, Intake manifold w/ Tial BOV, CP Ignition
AGP: GT3582R turbo kit
Mopar: Sway Bars, S3R CO, Ti Strut Bars,
Rage-Tek: LCA, TOB, Triple Fuel Pumps, 1000cc Inj 3/4 fork
Autometer: WB, Boost, Oil PSI, Oil Temp, EGT, FP
ClutchMaster: Twin Disk
AEM: EMS w/ 3.5 BAR sensor
JMB: 4in Intake, Hotside Hardpipe
Boomba: All 3 MM
Yea i know it's linear and adjustable. I purposely only did a 10.0-18.0 afr so that it would be the same as a 0-5v line with 10.0-20.0 afr. I can unplug the gauge and the gauge and ems both read the same. but after I have it plugged up and running again it will be off.
Yea I guess I'm gonna have to. I was just hoping I wouldn't have to do all the math.
lol get used to it
even with a voltage scale that is straight from the manufacturer there will still be a deviation due to voltage drop across the wiring.you will still need to go into the calibration graph and adjust accordingly
Email: Jay@N2MB.com
take a moment today to reflect on what happened on 11 september 2001...
I know about voltage drop across a wire but damn enough for their to be a whole piont difference? I'm gonna wait til my Dis-4 comes back before I do anything else, though cause the car is running rough in the lower rpm range without it.
make sure to set the dwell wizard to capacitve discharge ignition not dodge or msd coil or it will fry your ems
