Old 06-06-2008, 07:07 PM   #1 (permalink)
Member Number: 42667
Default Air fuel ratio tuning math question
The question is:
Lets say at a certain throttle position I am running very rich and want to remove X amount of fuel from that area using the throttle correction map. How do you go about doing the math to figure that out?
As an example. At 31% throttle i'm running a 10.5:1 AFR's all the time at this throttle position. I want it at 12.0:1. How do you figure out the math to get it close to where you want it to be?
05plsrt4 is offline   Reply With Quote
Old 06-07-2008, 07:34 AM   #2 (permalink)
JANNETTYRACING's Avatar
Member Number: 10982
Quote: Originally Posted by 05plsrt4 View Post
The question is:
Percentage, Remove 14% fuel
JANNETTYRACING is offline   Reply With Quote
Old 06-07-2008, 08:34 AM   #3 (permalink)
I mean how did you come up with the 14%
Old 06-07-2008, 08:51 AM   #4 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (45)
the difference between 10.5 and 12.0 is 14 %
Email: Jay@N2MBRacing.com
Old 06-07-2008, 09:30 AM   #5 (permalink)
I see. I'm brutal with math. I was tryin to do a percentage but just couldnt figure out how to get the correct percentage to start with
Old 06-08-2008, 11:15 AM   #6 (permalink)
Trader Rating: (45)
well you can either use a calculator and take the number that have and multiply it by a percentage and get your number or here is an even easier way
go into your target air fuel map under o2 feedback and make a cell the number you have. then hit m for menu and e for percent change and starting at 100% add or subtract percentage. for example make a cell 12.0 and hit m,e and 86 enter (100% - 14% = 86)it will change the box to 10.5.same goes the other way make it 10.5 then m,e 114 and enter and it will add 14% to get 12.0
Old 06-08-2008, 02:23 PM   #7 (permalink)
lilmike0450's Avatar
Member Number: 56278
holy shit....
05 White ACR
lilmike0450 is offline   Reply With Quote
Page generated in 0.18657 seconds with 11 queries
