Old 04-26-2008, 02:22 PM   #1 (permalink)
MKonmac's Avatar
Member Number: 24666
Trader Rating: (15)
Default AEM wont pick up cam sensor
I need help! i have sent my box back and it is still doing the same problems.
symptoms... (note it will start and drive wonderfully on stock ecu)
1. The car will crank and crank but not turn over
2. In the cam sensor area (not sure where this is, shop that i am having tuning it showed me) it is showing no reading. not even a small movement in numbers.
3. I remove the sensor with stock ecu it still starts but goes into "limp mode"
4. I put the sensor back on reset stock ecu and it runs beautiful.
SO i know the sensor works!
Is there a setting i must change to get this aem box working on my car???
thanks in advance
Matt'!~
AEM with goodies untuned
Agp 60-1 turbo
3" exhaust w/ ecutout
Custom HUGE FMIC
Meth injection
HKS BOV
AGP Dogbone MM
Maddog 50% short shifter
walbro 255 w/Fuel Return Line and 750 injectors pwerks stg 3 tranny/CM stg 4 clutch
IP2 Carbon fiber hood
Shaved Front emblem and antenna
Painted Outside B Pillars
Niteshades Custom Painted Tails and side markers
Eyelids
Before AEM 11.78@119mph 25.5 lbs boost
MKonmac is offline   Reply With Quote
Old 04-26-2008, 03:12 PM   #2 (permalink)
nutz's Avatar
Member Number: 41700
do you have a base map for startup ??
have you had the vehicle running prior to this on the ems
Old 04-26-2008, 04:35 PM   #3 (permalink)
MKonmac's Avatar
Trader Rating: (15)
Yes it was running and then it stopped thats when we sent it back to aem.
yes there is a start up map loaded
I have also tried 4 other maps found on here
Matt'!~
Old 04-27-2008, 04:06 PM   #4 (permalink)
MKonmac's Avatar
Trader Rating: (15)
Bummp!
Old 04-27-2008, 10:30 PM   #5 (permalink)
MKonmac's Avatar
Trader Rating: (15)
anyone??
I want to get it tuned!!!
Matt'!~
Old 04-27-2008, 10:40 PM   #6 (permalink)
SRTforums Veteran²
onthedwnlow's Avatar
Member Number: 27125
Trader Rating: (43)
that should not keep it from starting....it usually just goes off the crank signal.....i dont think the aem even reads that cam signal
sorry guys but the car is for sale....all out first gen is in the works
onthedwnlow is offline   Reply With Quote
Old 04-27-2008, 10:54 PM   #7 (permalink)
Member Number: 19053
Trader Rating: (10)
is the fuel pump turning on? manually crank the motor with the key in the on position and see if the pump turns on. That will tell u if the cam sensor is working.
ghost-1 is offline   Reply With Quote
Old 04-27-2008, 10:57 PM   #8 (permalink)
Trader Rating: (10)
silly Q did you go to setup>cam/crank>cam/crank wizard?
Old 04-27-2008, 10:58 PM   #9 (permalink)
Trader Rating: (10)
send me your map.
Old 04-28-2008, 12:50 AM   #10 (permalink)
nutz's Avatar
well basic engine is fuel and fire.....check for both....even any fuel/spark timing was off it should try to start
kinda sounds like ignition outputs fried ...or your program got a mistake, but if you tried to upload diferent base maps that should correct it
you sent it back to ems for repair??????????
Old 04-28-2008, 09:48 AM   #11 (permalink)
duster360's Avatar
Member Number: 45182
Yes, the stock ecu will look for a crank AND a cam signal before it will re-energize the Fuel Pump relay. If the pump comes on WHILE cranking the cam signal is getting to the stock ecu. Note: the intial pump run when the key is on before cranking is automatic and NOT associated with the cam/crank signal
And yes of course the EMS uses the cam signal.
Old 04-28-2008, 11:05 PM   #12 (permalink)
Trader Rating: (10)
So whats the deal?
Old 04-28-2008, 11:26 PM   #13 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (45)
what cams are in the car?you can try this
Go to SETUP-->SENSORS-->CAMCRANK SENSOR-->ADVANCE CAMCRANK-->OPTIONS-SYNC SETUP
change Sync teeth from 1 to 3
Go to FUEL-->ADVANCE FUEL-->INJECTOR PHASING-->OPTIONS-INJECTOR PHASING
change injector phase from 2 to 8
Go to IGNITION-->ADVANCE IGNITION-->IGNITION PHASING-->OPTIONS-IGNITION PHASING
change ignition Sync from 8.38 to 14.38
Email: Jay@N2MBRacing.com
Old 04-29-2008, 09:17 PM   #14 (permalink)
MKonmac's Avatar
Trader Rating: (15)
So whats the deal?
Havent had a chance to go to the shop I have worked 2 14 hr days in a row and im beat. hopefully I can get there Wed night!
Thanks everyone!
Matt'!~
Old 05-12-2008, 09:31 PM   #15 (permalink)
Trader Rating: (10)
So get it working yet?
Page generated in 0.26997 seconds with 11 queries
