Old 01-29-2008, 04:52 PM   #16 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
Quote: Originally Posted by turbojack View Post
I'm looking at the sensor PDF's and on the web now. Three wire as I described. Kavlico use to supply these sensors to AEM (30-2155) I think they are using someone else right now.
Link to the sensor manufacture for the one you got on Ebay...possibly a part #?
my bad i got the gauge on ebay, if i find pressure sensors ill post it up
Old 01-29-2008, 04:56 PM   #17 (permalink)
nutz's Avatar
Trader Rating: (19)
1 Bar Map or 15 PSIA Sensor Kit
30-2130-15 $171.52
****100 PSIG Sensor Kit**** fuel/oil
30-2130-100 $171.52
1000 PSIG Sensor Kit
30-2121 $217.23
****150 PSIG Sensor Kit**** fuel/oil
30-2130-150 $171.52
2 Bar Map or 30 PSIA Sensor Kit
30-2130-30 $171.52
2000 PSIG Sensor Kit n2o
30-2130-2000 $171.52
3.5 Bar Map or 50 PSIA Sensor Kit
30-2130-50 $171.52
5 Bar Map or 75 PSIA Sensor Kit
30-2130-75 $171.52
500 PSIG Sensor Kit 1/8-NPT Male. Inc. -4 & Barb Adaptors.
30-2130-500 $171.52
72" Serial EMS Coms Cable
35-3001 $7.30
96" UEGO Sensor Replacement Cable for "Gauge-Type" Controller
35-3400 $17.93
96" UEGO Sensor Replacement Cable for "U" EMS
35-3511-96 $57.95
Air Inlet Temperature Sensor Kit
30-2010 $60.64
Boost Control Solenoid Kit
30-2400 $130.00
Bosch Fuel Injector Plug Kit
30-2020 $13.19
Bosch Wideband UEGO "Replacement" Sensor
30-2001 $75.22
Bypass Plug for Twin-Fire Capacitive Discharge Ignition Module. 4 Channel
35-3802 $20.03
Coolant Temperature Sensor Kit
30-2011 $40.62
Exhuast Gas Temperature Sensor Kit
30-2050 $172.15
K-Type Thermocouple Sensor Kit
30-2051 $108.60
Male Connector for Bosch Wideband UEGO Sensor
35-2613 $12.56
Micro-Relay Kit
30-2060 $19.95
Plug-N-Pin Kit for EMS 1002, 1040's, 1310, 1311, 1312, 1313's, 1710 & 1720
35-2611 $64.21
Plug-N-Pin Kit for EMS 30-1010, 1012, 1020, 1050's, 1052's & 1060's
35-2610 $64.21
Plug-N-Pin Kit for EMS 30-1500U
35-2612 $64.21
Plug-N-Pin Kit for EMS 30-1900 & 30-1902
30-2902 $87.50
Universal EMS Wideband UEGO Sensor Kit
30-2002 $149.93
Copyright © 2007 Advanced Engine Management, Inc. All Rights Reserved.
Best viewed with Internet Explorer 5.0+ at 800x600 resolution or higher.
Q: What fluids can harm AEM sensors? What fluids are compatible?
A: All AEM pressure sensors feature a 360-degree welded stainless-steel wetted area. What this means in plain English is that they do not have any o-rings or gaskets that the fluid can come into contact with. No typical automotive fluid will harm these sensors. They are compatible with Gasoline, Methanol, Ethanol, Nitro-methane, Hydraulic fluid, Nitrous Oxide, Brake Fluid and Oil.
All sensors come with a three- wire mating connector with 12" leads for ease of installation.
from what it looks like all sensors are 5v style i think any gm style should work, once again dont quote me
leads would be +"5v" -"sensor ground" return" o-5v"
Old 01-29-2008, 08:35 PM   #18 (permalink)
turbojack's Avatar
Member Number: 11814
Trader Rating: (122)
Nice job on the info its appreciated this is an instance where the forum rocks.
I just got an email, It looks like the sensors I got with my Aeroforce gauges may work with the AEM EMS which is good because it will save me some cash if it works out this way.
turbojack is online now   Reply With Quote
Old 01-30-2008, 12:12 PM   #19 (permalink)
tavenger5's Avatar
Member Number: 42245
Trader Rating: (29)
So which one of those could be used for fuel pressure?
I wish these gauges had two readouts, kinda like the aeroforce.
[font="Arial Narrow"]
2004 Black SRT-4 - all set for 500hp+
2005 Interlagos Blue BMW M3
tavenger5 is offline   Reply With Quote
Old 01-30-2008, 01:02 PM   #20 (permalink)
turbojack's Avatar
The sensors are universal. So "30-2130-100" could be used for either fuel or oil.
The AEM datagauge can display 19 channels. If will only display one at a time, so you could set it up to display AFR as a default and then setup triggers thresholds for the other 18, the gauge under normal circumstances will always display the A/F and IF say EGT were to meet or exceed the user set threshold then the gauge will start blinking and switch to display that channel. IMO its not a bad idea. You could get two or more gauges if you want to SEE live more then one channel but IMO the gauges cost too much for this + the dash gets too busy with gauges and on the SRT it does get to be gaudy at some point to have tacked on gauges all over the place......one or maybe two gauges in the same location as the stock boost gauge is workable.
Old 01-31-2008, 04:49 PM   #21 (permalink)
nutz's Avatar
Trader Rating: (19)
they will scroll threw all the functions you want/to have 2 seprate readouts at 1 tiome you can plug multiple gages into one another "no aditional conections except for +/-", the ones with the **** in front are for pressure like fuel/oil there is also one for your n2o bottle 2000 psi
http://i227.photobucket.com/albums/d...1121072158.jpg
Page generated in 0.16520 seconds with 13 queries
