Old 04-27-2006, 12:18 PM   #106 (permalink)
AWD_THIS's Avatar
Member Number: 6481
Alright. I'm going to go try it right now. Hope it works.
Thanks for all the help guys
AWD_THIS is online now   Reply With Quote
Old 04-27-2006, 01:03 PM   #107 (permalink)
AWD_THIS's Avatar
Member Number: 6481
Well we are up and running now. The only thing I am worried about right now is my 9.5 air/fuel at idle.
Old 04-27-2006, 01:32 PM   #108 (permalink)
Tex
Tex's Avatar
Member Number: 3622
haha yeah the base map sucks mokey butt!!! i had to pull a TON of fuel to get it to run right. some base map...i dont belive that aem made the power they claim with the crappy AFR's that the kit comes with right now
-Soren Kierkegaard
Tex is offline   Reply With Quote
Old 04-27-2006, 01:55 PM   #109 (permalink)
AWD_THIS's Avatar
Member Number: 6481
Tex did you do you do your own tuning? And if so how did it go. Hard or Easy. I have done some street tuning with the Emanage. I know it is not the same but I am hoping it is not that complicated.
Old 04-27-2006, 02:31 PM   #110 (permalink)
Member Number: 28133
If you rescale the Fuel Map for your bigger injectors you will be all set.
quick108 is offline   Reply With Quote
Old 04-27-2006, 02:44 PM   #111 (permalink)
Tex
Tex's Avatar
Member Number: 3622
tuning is cake, as long as you datalog stuff. my afr's were pig rich too, and im runnng stg1 injectors...and its setup for those injectors. however, after pulling alittle fuel it was good to go
Old 04-27-2006, 06:05 PM   #112 (permalink)
AWD_THIS's Avatar
Member Number: 6481
What screen are you using to pull out fuel.
is there an option to rescale?
Old 04-27-2006, 06:38 PM   #113 (permalink)
Tex
Tex's Avatar
Member Number: 3622
go to the fuel table. you can select individual boxes to alter or you can select the entire thing, right click --> change then select how many points you want to go up or down. positive numbers add fuel, negative numbers pull fuel. DO IT SLOWLY!!!!!!! too much and you can very easily toast your motor!!!
if your computer hasnt been calibrated for your injectors that too may be the problem. setup menu --> injectors --> primary injectors --> injector wizard select the proper injector size and it will reclalibrate your map to match
Old 04-27-2006, 07:05 PM   #114 (permalink)
AWD_THIS's Avatar
Member Number: 6481
Injectors are correct (750cc 12ohm)
Old 04-27-2006, 08:21 PM   #115 (permalink)
Tex
Tex's Avatar
Member Number: 3622
if its already calibrated, then your going to have to pull fuel. i pulled a large amount of fuel, couldnt tell you how much cause i dont remember, but i know it was a lot.
Old 04-27-2006, 10:42 PM   #116 (permalink)
AWD_THIS's Avatar
Member Number: 6481
Where is the best place to install the 3.5bar map sensor.?
Old 04-27-2006, 10:43 PM   #117 (permalink)
Tex
Tex's Avatar
Member Number: 3622
the factory map sensor is good upto 20.9psi. anything more than that and you can mount it on the fender well, or on the firewall, or any place you can fit it. well, thats assuming its like the GM map sensors and you run a vacume line to them
Old 04-28-2006, 06:23 AM   #118 (permalink)
yellowRS's Avatar
Member Number: 4817
Do you wire it in to the stock map sensor wires?
yellowRS is offline   Reply With Quote
Old 04-28-2006, 09:54 AM   #119 (permalink)
Not necessarily. The AEM SRT-4 Base Map has very good fuel resolution (45 Microsec/bit). So if you dropped the fuel map 10 points (bits) you haven't even taken out 1/2 a mS of injector pulsewidth.
Old 04-28-2006, 01:06 PM   #120 (permalink)
Tex
Tex's Avatar
Member Number: 3622
i took more than 10 out, thats for sure. it was running low 10's high 9's afr wise. now im in the mid 12s across most of the powerband. still needs some fine tuning, but thats life
