Quote: Originally Posted by
nutz
well when you figure something out post it up, if we all put our heads together it should be simple
i think some good old fasioned team work will put things in perspective
That is true!!! where do we start??? i guess the basics.
I myself have a small mod list ,
AEM EMS
DCR Oil Mod
Cold Air
BFMIC
i do have 50trim sitting here and still need a few parts but i nervous about putting it on cuz i dont feel i know enough about the EMS to put her on and i dont have the money to blow it up....
So to get this moving along im gonna ask questions then make a small How-to vid on it when i feel i know enough to make one... and Nutz i know you have enough knowledge to make a few..... SO first one
So i finally got my car to idle 800rpm with a 13.5 A/F
I CANNOT get it any leaner then 14 without it missing and running like crap.
What does everyone else got going on for RPM? and A/F? at idle?
to do this i first let the car come up to temp then turned off all trims(fuel and ign) made sure the fans where not running and nothing else was on or running that would put a load on the motor....
i simply selected the bottom 4 cells on the fuel map that idle was using and hit the minus botton on the keyboard untill it was around 13 - 13.5
i'm not sure if this was the correct way but if it was ill make a vid on it.
Now one question is this.
if you click on the Idle icon in AEM Pro it will bring up a few windows and one of them is "Idle% Vs Target Table"
In that table i was told to move the line until the "idle learned value" equaled 0 or slighty higher but when i did this for all RPM points the engine would die after letting off the throttle (coming to a stop light) or the engine would not start at all.... ALSO the engine idle would be set at 800 but the idle would be around 950 - 1000rpm...... What i did INSTEAD was put the "Idle Target Base Table"
to 800 rpm and moved the line on the "Idle% Vs Target Table" untill the idle was at 800. Does any of that make any sence?? or correct?
ohh and anyone using AEM Tuner yet?
