Old 06-09-2008, 04:38 AM   #16 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (45)
wow that makes me feel good lol
just so you know if you have that mindset that you afrs need to be 12.0 on race gas your asking for trouble.ems tuning is much different than map clamp tuning.best results would be anywhere around 11.3 which is where i usually targetyou will not gain much power (if any at all) leaning it out from 11.3 to 12.keep that extra fuel in there to suppress knock.make the power with timing not air fuel
Email: Jay@N2MB.com
Old 06-09-2008, 06:43 AM   #17 (permalink)
JANNETTYRACING's Avatar
Member Number: 10982
May I show you this article.
Many people with turbochargers believe that they need to run at very rich mixtures. The theory is that the excess fuel cools the intake charge and therefore reduces the probability of knock. It does work in reducing knock, but not because of charge cooling. The following little article shows why.
First let’s look at the science. Specific heat is the amount of energy required to raise 1 kg of material by one degree K (Kelvin, same as Celsius but with 0 point at absolute zero). Different materials have different specific heats. The energy is measured in kJ or kilojoules:
Air ~ 1 kJ/( kg * deg K)
Gasoline 2.02 kJ/( kg * deg K)
Water 4.18 kJ/( kg * deg K)
Ethanol 2.43 kJ/( kg * deg K)
Methanol 2.51 kJ/( kg * deg K)
Fuel and other liquids also have what's called latent heat. This is the heat energy required to vaporize 1 kg of the liquid. The fuel in an internal combustion engine has to be vaporized and mixed thoroughly with the incoming air to produce power. Liquid gasoline does not burn. The energy to vaporize the fuel comes partially from the incoming air, cooling it. The latent heat energy required is actually much larger than the specific heat. That the energy comes from the incoming air can be easily seen on older carbureted cars, where frost can actually form on the intake manifold from the cooling of the charge.
The latent heat values of different liquids are shown here:
Gasoline 350 kJ/kg
Water 2256 kJ/kg
Ethanol 904 kJ/kg
Methanol 1109 kJ/kg
Most engines produce maximum power (with optimized ignition timing) at an air-fuel-ratio between 12 and 13. Let's assume the optimum is in the middle at 12.5. This means that for every kg of air, 0.08 kg of fuel is mixed in and vaporized. The vaporization of the fuel extracts 28 kJ of energy from the air charge. If the mixture has an air-fuel-ratio of 11 instead, the vaporization extracts 31.8 kJ instead. A difference of 3.8 kJ. Because air has a specific heat of about 1 kJ/kg*deg K, the air charge is only 3.8 C (or K) degrees cooler for the rich mixture compared to the optimum power mixture. This small difference has very little effect on knock or power output.
If instead of the richer mixture about 10% (by mass) of water would be injected in the intake charge (0.008 kg Water/kg air), the high latent heat of the water would cool the charge by 18 degrees, about 4 times the cooling effect of the richer mixture. The added fuel for the rich mixture can't burn because there is just not enough oxygen available. So it does not matter if fuel or water is added.
So where does the knock suppression of richer mixtures come from?
If the mixture gets ignited by the spark, a flame front spreads out from the spark plug. This burning mixture increases the pressure and temperature in the cylinder. At some time in the process the pressures and temperatures peak. The speed of the flame front is dependent on mixture density and AFR. A richer or leaner AFR than about 12-13 AFR burns slower. A denser mixture burns faster.
So with a turbo under boost the mixture density raises and results in a faster burning mixture. The closer the peak pressure is to TDC, the higher that peak pressure is, resulting in a high knock probability. Also there is less leverage on the crankshaft for the pressure to produce torque, and, therefore, less power.
Richening up the mixture results in a slower burn, moving the pressure peak later where there is more leverage, hence more torque. Also the pressure peak is lower at a later crank angle and the knock probability is reduced. The same effect can be achieved with an optimum power mixture and more ignition retard.
Optimum mix with “later” ignition can produce more power because more energy is released from the combustion of gasoline. Here’s why: When hydrocarbons like gasoline combust, the burn process actually happens in multiple stages. First the gasoline molecules are broken up into hydrogen and carbon. The hydrogen combines with oxygen from the air to form H2O (water) and the carbon molecules form CO. This process happens very fast at the front edge of the flame front. The second stage converts CO to CO2. This process is relatively slow and requires water molecules (from the first stage) for completion. If there is no more oxygen available (most of it consumed in the first stage), the second stage can't happen. But about 2/3 of the energy released from the burning of the carbon is released in the second stage. Therefore a richer mixture releases less energy, lowering peak pressures and temperatures, and produces less power. A secondary side effect is of course also a lowering of knock probability. It's like closing the throttle a little. A typical engine does not knock when running on part throttle because less energy and therefore lower pressures and temperatures are in the cylinder.
This is why running overly-rich mixtures can not only increase fuel consumption, but also cost power.
JANNETTYRACING is offline   Reply With Quote
Old 06-09-2008, 07:18 AM   #18 (permalink)
Trader Rating: (45)
Gasoline 350 kJ/kg
Water 2256 kJ/kg
Ethanol 904 kJ/kg
Methanol 1109 kJ/kg
ive read that in a few places actually,thats a good read.i cant remember where i originally saw that i think it was on a water injection forum but i wish i had saved it,now i will lol
i think the srt is a slightly different vegetable though. and it all varies from motor to motor and setup differences.piston choice being the biggest variable.what i have found most effective is a low compression dished piston with a big exhaust side.offset pistons are a huge plus because they help keep the skirts from being driven into the cylinder walls at peak cylinder pressure. my worst results have been with high compression dome style pistons,squench is horrible and cylinder temps are just rediculous.those pistons for some reason remind me of a cattle prod lol. im also talking big differences in knock suppression even with a quality fuel.it seems every time i tune one with a high compression piston if the turbo has a small ar such like a .63 coming into boost there is almost always knock right around full spool.
anyway im getting a little off topic but ive had a bunch of srt4's that ive had strapped down and raised the air fuel to more efficient ranges like 12.0-12.5 and yielded minimul results.maybe a 5 hp difference but the tendency for knock with aggressive timing is higher.but as we both know it all boils down to ve ..if you have a motor that is basically stock with around a 90%ve you are going to have alot of isues with aggressive timing with a leaner afr as opposed to a motor built right with a 94 or higher ve.on a competition motor i agree 150% with you on specific heat and latency
i hope that you plan on hanging around this forum more often i love to hear other peoples theories
Old 06-09-2008, 07:20 AM   #19 (permalink)
Trader Rating: (45)
im moving to florida in a couple weeks and ill be up every couple months for tuning but if i cant make it up to tune a car i will most definately send them your way.a question i have been getting almost daily is who is going to tune my car when you leave..glad i can answer that now
Old 06-09-2008, 07:54 AM   #20 (permalink)
I apprciate the Support.
What I have found is that the engines accelerate harder with 12.0 and less timing than they do with 11.5 and more timing.
Damn I am giving away all my secrets LOL!
Old 07-03-2008, 11:33 PM   #21 (permalink)
FraziersSRT's Avatar
Member Number: 37867
Trader Rating: (44)
Gasoline 350 kJ/kg
Water 2256 kJ/kg
Ethanol 904 kJ/kg
Methanol 1109 kJ/kg
Good read!
FS : Stage 3 PCM w/toys,RC 650's,Mopar CAI!! PM ME!!
http://www.srtforums.com/forums/f27/...intake-463771/
FraziersSRT is offline   Reply With Quote
Old 07-04-2008, 12:00 PM   #22 (permalink)
duster360's Avatar
Member Number: 45182
link and proper accreditation
"You CAN be too Rich"
By Klaus Allmendinger, VP of Engineering, Innovate Motorsports
duster360 is online now   Reply With Quote
Old 07-04-2008, 12:06 PM   #23 (permalink)
duster360's Avatar
Makes sense if the timing isn't reduced along with the leaner A/F. The logic in Klause's paper is the set the proper A/F and then optimize the timing for it. If you have the mindset that more timing is often better, then of course, a richer A/F will be needed to supress knock. Don't ignore the fact that starting the combustion later via retard timing will also suppress knock by limiting the time availible for heat transfer.
Page generated in 0.33278 seconds with 11 queries
