Old 10-19-2009, 07:21 PM   #1 (permalink)
boots's Avatar
Member Number: 67116
Default AEM anti-lag or wot box?
I want to get a WOT feature setup on my car for the track and wasn't sure which one would be the better, easier setup, and most beneificial?
2004 stage 2-AEM ems-DCR intake manifold-crane 16's(stock valve train)-Rage Twin disc-dss axles-boomba fuel rail-boomba mounts-boomba throtle body-3in side exit exhaust- maddog 58 STS-built trans( Rage accelerator, Rage 3/4 fork, and p-werks selector)- GT3076R
Soon to come, my high compression build New turbo setup and transmission setup
boots is offline   Reply With Quote
Old 10-19-2009, 07:44 PM   #2 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (20)
twards the end of the EMS manuel it explains how to do a WOT type shifting feature with the EMS (switch type retard) in the options you can change the amount of retard for WOT shifts, I wanted to do a WOT retard on the clutch up switch and an anti-lag on the clutch down switch
this way on the inital contact of the clutch the EMS will reduce power for shifting, and on full clutch disengauge the anti-lag feature would be set for building boost
chuck played with this (not the same way) and the anti-lag was good. I dont know how this would stack up against one of N2MB's boxs for WOT shifting
JDP (gett'n dirty as a mo-fugger)
Old 10-19-2009, 07:56 PM   #3 (permalink)
boots's Avatar
yea, I need need to read over the manual some more. I just wasn't sure what people prefer. I think Erabbit runs EMS with the n2mb's WOT box. I just want to get something setup, because last time I was at the track I WOT and I don't think my clutch liked WOT shifting at 6500. I will hopefully be getting a Rage twin disc soon, but I still would like to setup a WOT feature.
Old 10-19-2009, 08:03 PM   #4 (permalink)
nutz's Avatar
Trader Rating: (20)
yea the WOT feature should reduce power just before clutch disengagement for ease of shifting, you could try the retard function if its no good then get a WOT box. I am not sure what the WOT box does, if its just a clutch controled retard or something more
Old 10-19-2009, 08:15 PM   #5 (permalink)
boots's Avatar
Yea, I'm not sure about the WOT box, I think it is clutch controlled. Is there a how-to to setup the retard function? Like I said I'm still fairly new to the EMS, but I know my way around it some what.
Old 10-19-2009, 08:18 PM   #6 (permalink)
nutz's Avatar
Trader Rating: (20)
naa no how too but I can write one up when I get home from work, should be easy to do
Old 10-19-2009, 08:22 PM   #7 (permalink)
boots's Avatar
I would greatly appreciate it. My local track closes the 25 and would like to see how this would improve my time. After the 25th I think the only track that is open is Dragway 42 which is 2hr's away.
Old 10-19-2009, 08:27 PM   #8 (permalink)
Member Number: 30696
damn, i wish i had a drag stip only 2 hours away! the close one sucks (never prepped) the 2 hour away one are nazi's about tech, and the 4hour away one is the house of hook.
amdguy is offline   Reply With Quote
Old 10-19-2009, 08:31 PM   #9 (permalink)
nutz's Avatar
Trader Rating: (20)
if I do the right up, you will need to test and post on how to tune it (my car see's about 5 miles a year ) deal
Old 10-19-2009, 08:34 PM   #10 (permalink)
boots's Avatar
Deal most likely I will mess with it a bit, but my friend who tunes for me will do most of the setup. I'll post up the results for sure, thanks for the help
Yea I have National trail raceway which is 30min from me(it's a decent track) but it closes the 25th. So after that I pretty much only have Dragway 42 that is 2hrs away. I think it's where Realtune goes for test runs.
Old 10-19-2009, 08:46 PM   #11 (permalink)
nutz's Avatar
Trader Rating: (20)
i will get on it tonite and have it up in a day or two
