Old 11-04-2009, 10:45 AM   #1 (permalink)
Member Number: 75700
Default 6k rev cut, but commanding 7200
Ive been having trouble with this one for two weeks now. The ECU will randomly cut fuel/ignition between 6200 and 6400. If it doesent, it will allow me to hit my target limiter. Boost cut is well above my boost pressure. I have been in contact with AEM and we are still working on it. Just seeing if anyone else here has ran into this problem before and if they resolved it.
Items Ive replaced-
Cam sensor and magnet
coils
plugs
Logs upon request.
Its a
DCR option b engine
Their "Race" port head
GT3582r
bc3 cams/springs
1000cc ids
Boost controller is wired into ems
no tip solenoid, wastegate and surge valve, all taken out.
so far on 19lbs its making 495 at 7200rpms(when it does work)
taylork057 is offline   Reply With Quote
Old 11-04-2009, 09:46 PM   #2 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
Items Ive replaced-
coils
plugs
Logs upon request.
Its a
DCR option b engine
GT3582r
bc3 cams/springs
1000cc ids
post up a .cal, it could be lots of things if you can post the cal file up and a log of a dyno pull (or street pull) when it happens
Old 11-22-2009, 08:32 AM   #3 (permalink)
d_fl8ted1's Avatar
Member Number: 11549
Trader Rating: (81)
Sounds like an electrical issue.... check all grounds... add grounds... and check all wires that are spliced and makes sure nothing is exposed... sounds similiar to an issue i had at one time..
When this happens does your computer screen freeze up while loggin?
On the 8th day GOD created drag racing
d_fl8ted1 is offline   Reply With Quote
Page generated in 0.11436 seconds with 13 queries
