Old 01-22-2008, 02:40 PM   #1 (permalink)
Member Number: 59439
Default 3bar map sensor makes car lobe... HELP!!!
I installed my Mopar 3bar map sensor this weekend, well it made my car lobe... sounded badass but i;m sure its not suppose to do that, then the exhaust fumes started smelling real bad(yea weird). I'm running the stock pcm, any idea as to why my car would do this? or should i upgrade my pcm?
cacahead is offline   Reply With Quote
Old 01-22-2008, 02:44 PM   #2 (permalink)
Silver SRT4's Avatar
Member Number: 17735
how am I suppose to take you serious with a S/N of cacahead...
SRTs are better than everything ever. period. Car, plane, rocketship, anything. There has never been anything in existance as fast as an SRT-4. Scientists have been considering changing lightspeed to SRT-4 speed, but havent been able to because light cant keep up.
Silver SRT4 is offline   Reply With Quote
Old 01-22-2008, 05:36 PM   #3 (permalink)
Ummmmm??? anybody else?
Old 01-22-2008, 08:52 PM   #4 (permalink)
JesseL's Avatar
Member Number: 51882
I started to type a serious response...
Then I said fuckit.
Don't do anything, just keep running it. It adds like 50hp.
JesseL is offline   Reply With Quote
Old 01-23-2008, 06:49 AM   #5 (permalink)
i'm asking seriously
Old 01-23-2008, 05:15 PM   #6 (permalink)
Member Number: 27506
Do you have the AEM EMS with the stock PCM or just the stock PCM??
Why are you posting in the map section BTW????
Tein S-techs, Tokio 5-ways, AEM-EMS, MPX intercooler, MPX Exhaust, MSD 8.5mm wires, Traction bars, 03 with LSD
AGP 3147, Injen SRI, ACT 6 puck, AGP MM, ED hard pipes, Greddy BC, ES bushings, DSS stg 3s.
650whp or bust
DGR8srt is offline   Reply With Quote
Old 01-24-2008, 06:15 AM   #7 (permalink)
actually i just have the stock pcm, and i didn't notice i was posting in the wrong section. Sorry
Old 01-24-2008, 09:16 AM   #8 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (30)
yea buddy you need to take that map off. if your running a stock pcm your only going to run lean up top and eventually add a couple of vents to the block. you need a stage 2 or stage 3 pcm to use a mopar 3 bar map sensor.
Old 01-24-2008, 09:31 AM   #9 (permalink)
NoisufnoC's Avatar
Member Number: 136
3 bar map sensor must equal hp...right?
you fail. the stock PCM is not calibrated for the range the 3 bar map puts out. You have two options, put the stock sensor back in or install a stage 2 or stage 3 PCM.
omgz!! i haz mods!!
Old 01-24-2008, 09:39 AM   #10 (permalink)
Please install stock map sensor now before you mess ur engine up.
Old 01-24-2008, 10:40 AM   #11 (permalink)
$PK$'s Avatar
Member Number: 47676
I laughed after reading every reply to this thread
On a serious note, its only bad if you only run the 3 BAR map sensor and not the TIP. You won't see the 50whp gain on only the 3 bar map, you need the 3 bar tip also
401whp 419wtq on pump gas tuned by Jannetty Racing Enterprise
$PK$ is offline   Reply With Quote
Old 01-24-2008, 12:15 PM   #12 (permalink)
yea i put the stock map sensor back on, i was sure the car wasn't suppose to lobe like that. And the only reason i bought the 3 bar was because i put my boost controller on, and my CEL came on with an oveboost code.
Old 01-24-2008, 02:36 PM   #13 (permalink)
JesseL's Avatar
I have a 3bar map and no tip sensor at all
Old 01-24-2008, 04:59 PM   #14 (permalink)
$PK$'s Avatar
Damn, your probably losing major crank horsepower
Old 01-24-2008, 05:01 PM   #15 (permalink)
NoisufnoC's Avatar
Member Number: 136
what is lobe?
Page generated in 1.46112 seconds with 11 queries
