Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > AEM EMS Workgroup > EMS Maps
Old 06-11-2006, 08:10 PM   #1 (permalink)
Tex
Tex's Avatar
Member Number: 3622
Default Tex's AEM base map
i wanted to upload this here for you guys. i have recieved numerous questions and requests for my basic map. i decided, since no one is sharing their maps, that i will put up what i am currently working on. this map, in no way substitutes for a professional tune. of course, you will need to verify that your AFR's are in hte safe range before driving or boosting. this car has camshafts with larger duration than factory and therefore has required less fuel injector pulse at idle and in lower rpms. this map, run on any car with factory camshafts, will cause your vehicle to run excessivley lean, even dangerously lean. again, be sure to confirm your AFR's are in the safe range before opperating yoru vehicle.
my modifications that will matter to tunning:
K&N air filter
3" custom turbo back exhaust with catalytic converter
crane 12 cams (intake advanced 2*, exhaust retarded 3*)
Mopar stage1 injectors (stock injectors on 04/05 vehicles)
NGK 4306 plugs
180* thermostat
***i, in no way, accept no liability for any damages that may occur do to uploading or attempting to run my computer map. this is meant to be used only as reference in your own tunning adventure.***
my map
on a side note, i dont know why people are so "hush-hush" about sharing maps. i understand if a shop tuned it, that they dont like giving it out beause is hurts buisness. however, the fact that all cars have different mods means that no premade tune is going to work great. AEM has incouraged me to share the maps and get as many others to share as possiable. so i ask all those reading this to post them up as well. lets make this a thread where people can look for insight while tuning their own vehicles. this wont replace the need for legit tuning shops, but will allow people to save some money by doing the work themselves
-Soren Kierkegaard
Tex is offline   Reply With Quote
Old 06-11-2006, 08:14 PM   #2 (permalink)
Member Number: 2096
Unrelated, but have you dynoed that set-up with the EMS? I'm curious as to what kind of power it put down.
xmdfmk7x is offline   Reply With Quote
Old 06-11-2006, 08:17 PM   #3 (permalink)
Tex
Tex's Avatar
Member Number: 3622
no. complete street tune...and let me tell you its still rough. its just a week or two before a big turbo, complete fuel system, and some other goodies go on. i dont want to deal with dyno tuning when its going to change within the month. i have not touched the timing map, just a bit of boost, fuel, and lots of driveability crap
Old 06-11-2006, 08:23 PM   #4 (permalink)
Project Blue
SRTforums Admin
Member Number: 1161
I don't share my maps for one reason
I am a perfectionist and I can't stand how my car is running right now still fixing the decel issue where it goes way to rich
Tex you can PM me and I can attach here on the forums.
http://www.hybridsrt.com
In remembrance of Andrew "HybridKid" Chin Shue
In remembrance of Steven "NightShade" Lorenz
FastAttack is offline   Reply With Quote
Old 06-11-2006, 09:32 PM   #5 (permalink)
Project Blue
SRTforums Admin
Member Number: 1161
eh I ended up attaching it for you
Old 06-11-2006, 09:33 PM   #6 (permalink)
Tex
Tex's Avatar
Member Number: 3622
thanks a ton fastattack.
its attached in 2 different forms there guys. one of them should work. let me know!!!
Old 06-18-2006, 11:37 PM   #7 (permalink)
DrmCtchr's Avatar
Member Number: 38971
My car, while profesionaly tuned, is running like supreme doodoo. I'm not really sure why. I'm getting almost ready to tune this on my own, but I'm still getting help from the shop that tuned me to begin with. It ran well for about 350 miles now idle has gone to an ocillation of several 100 rpms and power is starting to decrease and boost isnt well regulated. The car is 'running', but its not something I will share till the basic drivability stuff is corrected and such.
I will put something up as soon as I get something decent *IF* i get write off from the tuner that I can share it.
David
DrmCtchr is offline   Reply With Quote
Old 06-19-2006, 12:11 AM   #8 (permalink)
DrmCtchr's Avatar
tex your o2 sensor #1 gain is at 2.0 what wideband are you using?
o2 sensor #2 isnt stock.. same as #1
the ignition map differs pretty significantly from the base map .. how did you arrrive at the changes?
also you have a wierd entry on the injector advance map at 4.5krpm and load of 18.31 did you do that on purpose? the base map is flat at 357 from 2050rpm at any load to redline you have an entry of -25.31 there this is a very significant difference.
There is a random entry in the variable valve control valve#1 table at 4200rpm load of 5.28 should be zeroed you have it set to 36.3 =]
oh yah and one last thing.. can your stock WGA really hold 19.27 psi!!! =]
oh and im running 43 degrees dwell now as well .. 42 wasnt quite enough.
David
Old 06-19-2006, 12:26 AM   #9 (permalink)
Tex
Tex's Avatar
Member Number: 3622
factory uego box. played with it until the voltage is set where it should be. it doesnt read the secondar o2 sensor
i have not touched my ignition map...but have an OLD box. is the new software higher or lower specs than mine???
where exactly, what menu?
again where
yes, and it runs real nicely as well
im currently up to 44 and it seems cherry!!!
there is somthing really goofy with the software i recieved from AEM. the AFR units were setup to confir with methenol, so it was running like crap. the car barley idled let alone drove. i may just download the newest map and start over. this might be where some of the hickups are coming from
i am really dying to know what the new timing map is like.
Old 06-19-2006, 09:26 PM   #10 (permalink)
DrmCtchr's Avatar
wait .... for some reason I miscompared the ignition map yours only differs from the new one in 2 places.
the inj adv map is fuel><<advanced fuel>>>injector phasing>inj advance map> table
vvc valve #1 is setup><<advanced setup>>>variable valve control>valve #1
Old 06-19-2006, 09:41 PM   #11 (permalink)
Tex
Tex's Avatar
Member Number: 3622
i am baffled at those 2 anomolies. i have yet to tune either map...like i said. the aem map i got was way goofy. the car ran like crap. 5psi boost, stalled whenever you got off the throttle, etc. to be honest, im surpised how well i have made it run since then!!!
Old 08-01-2006, 07:51 PM   #12 (permalink)
Member Number: 18856
K&N air filter
NGK 4306 plugs
180* thermostat
my map
Sharing a map shouldn't be a problem all car engines are built in a way individually thus my map can be completely different from the guy with the same mods. Machines build cars on an assembly line and machines aren't perfect. I spent couple hundred for a dyno tune and if i can save a guy some cash than why not share.
joe smalls is offline   Reply With Quote
Old 08-15-2006, 03:53 PM   #13 (permalink)
benmcc2003's Avatar
Member Number: 27591
should have a rough big turbo map soon. working on idle right now. I am also suing the AEM boost solenoid, and AEM 5bar map. these were a ton of fun to get going. but seems like all is well right now. I am not boosting till i sit on the dyno for a few. but this week maybe.
AEM reccomended the Peak & Hold Injector Driver for the RC750's saturated injectors. to get a good 14.7 or so idle. so that may be next.
Built motor, AEM EMS, DBB 50. gets the job done.
benmcc2003 is offline   Reply With Quote
Old 08-17-2006, 08:08 AM   #14 (permalink)
macsperformance's Avatar
Member Number: 41778
Hi friend!
Not trying to correct here, just want to make sure they did not tell you the wrong thing.
They more than likely ment to say use low impedence injectors with the Peak & Hold Injector Driver. As Saturated Injectors are used with the drivers already installed in the AEM Plug and Play ECU.
Chris Macellaro
Macellaro's Performance Tuning
EFI University Instructor
Mustang Video
Camaro Video
MPT Video
Base Fuel Table Tuning Video
macsperformance is offline   Reply With Quote
Old 08-17-2006, 08:38 AM   #15 (permalink)
benmcc2003's Avatar
Hi friend!
Chris Macellaro
no you are right on, i was thinking that one back-ass. I beleive they mis-understood what i was talking about. I think they thought i was using the low impedence RC 750's. i never made it clear what injectors i was using to AEM.
thanks for the correction
Ben
Page generated in 0.26707 seconds with 14 queries
