this section has become somewhat stagnant...but im going to be changing that soon. my modified stage3 map will be up shortly. it is running frickin AWESOME at the moment. running just shy of 25psi, still working on the boost mapping. timing hasnt been touched yet, because i just fixed the darn "computer stall at WOT" that the AEM software glitch causes. afr's are low 12's/high 11's at WOT. NO knock at all!!! cruising at freeway rpm/load, afr's are 15.3:1 which brings good mileage with it. idle is smooth and tip-in is flawless.
this will work wonders for stage3 cars with cams, hahn 16g cars with cams, and hahn 20g with cams. should be good for small AGP kits as well. i strongly recomend cams, becase i have noticed that they change driveability more than even the larger snail.
stay tuned
stay tuned
way to step it up Tex, I have more dyno time Thursday. so i will post up a new map. had some fuel issues. But replacing all the lines this weekend so I should be set. I will post the map up when i am done.
stay tuned
