Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > AEM EMS Workgroup > EMS Maps
Old 05-10-2008, 11:20 PM   #1 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
Default some maps
couple maps i felt like throwing up here
one is a 50 trim without boost control.750 injectors fp boost source 42psi
edit: the 50 trim map was tuned on c16 race gas
the other is a 60 trim with vss boost control 12# gate spring 750 injectors fp boost source 40 psi
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 05-16-2008, 10:18 PM   #2 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
way to post up man
Old 05-18-2008, 12:08 PM   #3 (permalink)
nutz's Avatar
Trader Rating: (19)
i love you aproach to idle the 50 trim map
jay you are the master !!!!!!
Old 05-18-2008, 12:24 PM   #4 (permalink)
Trader Rating: (59)
thanks man, btw i forgot to mention i will edit it in my first post but the 50 trim map is a c16 map.it has some rather aggressive timing.
Old 08-07-2008, 10:33 PM   #5 (permalink)
ptc01's Avatar
Member Number: 1771
Wow! . . . It sure looks rather agressive.
2005 Import Wars Slick Class Champ New England Dragway
2006 SRT Nationals Champ Heartland Park Topeka Kansas
2006 Class Winner Englishtown New Jersey
2006 Top Eliminator Englishtown New Jersey
MODS: Darrell Cox Racing Built. 10.583 @ 130.87
ptc01 is offline   Reply With Quote
Old 08-08-2008, 10:41 AM   #6 (permalink)
Trader Rating: (59)
pulls like a muthafugger too
Old 08-16-2008, 09:25 PM   #7 (permalink)
Member Number: 44696
Trader Rating: (17)
I am a newbie what do you mean by fp boost source 42 PSI
Perrin FMIC and fuel rail, 50 Trim turbo, ported tb,Bwoody MM, PTP CV, BDJ 3" Exhaust, CAI 3" JMB, 160 Stat, BDJ Heatshield, iridium plugs w/msd 8.5mm, Mopar STS, Redstar return fuel system, Innovate WB.
Best 11.96 @123 MPH
Street Gear is offline   Reply With Quote
Old 08-16-2008, 09:35 PM   #8 (permalink)
nutz's Avatar
Trader Rating: (19)
fuel pressure is set at 42 and the 1:1 rise is off the boost source
Old 08-18-2008, 03:47 AM   #9 (permalink)
Trader Rating: (17)
OK I am studying his 50 trim map. I looked over the fuel map and couldn't make out what was going on. It appears nothing in his fuel table goes over 30% duty cycle. How does it work? Am I missing something here? Most maps I have looked at gets to about 90% duty in the high pressure high RPM range. Is this an actual working map?
Old 08-18-2008, 09:16 AM   #10 (permalink)
Trader Rating: (59)
yes that is an actual working map.if you look at the fuel map in duty cycle the numbers are low because they are uncorrected before modifiers do their job.the duty cycle numbers that you see on the map itself really dont mean diddlysquat.usually you will see high numbers in duty cycle if you are tuning a naturally aspirated car or not using boost compensation.what really matters is the duty cycle that you see when you look at your logs in which this case they were probably somewhere between 85-95% which is what i usually try to target.
like i said though the injector duty cycle when you log is corrected after modifiers and that is the number you should be looking at.go into advanced fuel and look at the boost fuel correct table and you will see the correlation between raw duty cycle and fuel percentage at high load and rpm
Old 08-18-2008, 10:20 AM   #11 (permalink)
Trader Rating: (17)
What would I do without the forum? Read over complete manual 3 times but yet still know very little. I looked at your modifier and it now makes sense but why use the modifier instead of just making the table as close to reality. Also why am I not able to see the map sensor and injectors you are using? On other maps when I open the map sensor wizard and injector wizard the sensor and injectors are checked beside the one the person is using. I know you setup the breakpoints to correspond to the areas in use but how does the program know if it is 3 bar or 5 bar you are using and the injector size?
Old 08-18-2008, 10:46 PM   #12 (permalink)
Trader Rating: (59)
interesting..i wonder why it doesnt show..either way it was 750 injectors and mopar 3 bar map sensor.as far as using the modifiers....well thats just preference and it has always been a hot topic between tuners using boost compensation or not using it.guys who tune alot of turbo cars mostly use it.i still use it on n/a cars though too.obviously no correction for boost but by going negative in vacuum you can really increase the resolution in the map for excellent driveability
Old 11-20-2009, 04:36 PM   #13 (permalink)
dodgez's Avatar
Member Number: 1795
Trader Rating: (15)
I used your timing tables for 3300 rpms and up...
Ran the SRT tonight.
Can't spell and have bad grammar??? click here
Quote: Originally Posted by red04@FM
You don't know anything. Look at the time it took for him to get back to us. We do more then what we should to help out customers.
dodgez is offline   Reply With Quote
Page generated in 0.14060 seconds with 14 queries
