Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > AEM EMS Workgroup > EMS Maps
Old 11-04-2009, 07:12 PM   #1 (permalink)
Member Number: 30934
Default Looking for a possible map.
Just bought this car off this guy supposed his first ecu was stolen and had to replace it so has just a basic tune in it. The car has a GT35R stage 3 bc cams stock valve size ported head ported intake ported throttle body agp race ic. No intake straight filter on turbo. Big kicker 650 rc injectors (for now). Any ideas on a good map. only running of waste gate spring right now vacuum line not hooked up (15lbs). Also he said to not hook up the first O2 sensor is this correct? Also have 5bar map sensor.
Gringo3825 is offline   Reply With Quote
Old 11-05-2009, 04:56 PM   #2 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
even if there was someone with the same exact mods it wouldnt work well for you, the EMS must be custom tailored for each car (unlike the stock ECU sct/dsp) your best bet is to take it to a pro to go over the install and get the tune close. you need a wide band to make the EMS wok properly (not an option) but the stock o2 sensors are not needed. start reading these forums and the AEMpower forums and read and re-read the manual every time you learn something new
next time try to post in the ems section, this section is reserved for people to POST maps and discuss their tunes, if you would like some feed back on your tune post it up
Page generated in 0.10613 seconds with 13 queries
