Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Technical Discussion > Technical Tuning & EFI/EMS Electronics > AEM EMS Workgroup > EMS Maps
Old 09-17-2009, 06:40 PM   #1 (permalink)
Member Number: 42667
Default Can someone critique my tune?
I've pretty much changed my entire tune and was wondering if someone would look at it and see what they think.
05plsrt4 is offline   Reply With Quote
Old 09-17-2009, 06:44 PM   #2 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
do you have a mod/sensor list and anything you want looked at (any glitches)
Old 09-17-2009, 06:53 PM   #3 (permalink)
mods that make a difference: 8.5:1 compression, bc stage 3 cams, CNC port head, 50 trim, 900CC injectors. AEM 3.5bar, GM IAT sensor, return line on boost/vac source base pressure 43PSI.
O2 feedback sucks ass. It takes forever to get to its target. No matter what gets changed (its 100000000000 times better than the wizard right now...but no where near perfect)
Hot start problem that i've complained about since i've owned the EMS....let it sit for 10-20 min after driving around and then restart it, it runs lean (18-19:1 afr's for 10sec-2min) then settles itself out.
Warm-up enrichment afr's are different EVERY TIME. This confuses me. It could be the same temp outside, same IAT's, same everything and it'll be at 12:1 once and 14:1 the next.
Slowing to a stop, as soon as you're out of decel fuel cut, it runs 12:1 until you reach a complete stop....then it idles normal again. (even though it sits in the same cells as the idle)
might think of more later.
Old 09-17-2009, 07:09 PM   #4 (permalink)
it has a 13.5:1 idle without O2 feedback on, runs 14.5:1 to 15.0:1 through out the RPM and vacuum range till approx 5inhg then it runs 13.5 and progressivly richer up to an 11.2-11.5 under boost without O2 feedback on.
What makes you think thats too much fuel at low RPM's?
Will not idle leaner than 13.5:1
Old 09-18-2009, 02:33 AM   #5 (permalink)
nutz's Avatar
Trader Rating: (19)
nice mod list
yea you took out most of the gain on the o2 fb
may be your o2 FB is delayed big time in the cold and you need enrichment we need a cold start logw/ the start screen parameters
its based on the coolant temp
i would need to know what your lowest load is in psig and may again be tied to the o2 FB
the map looks nice (100% boost comp) i think your idle % map needs to be finished, and your idle fuel and ign. FB needs to be toned down. and you dont like much timing above 15 psi do ya (I assume its a pretty big turbo)
i would lower your RAW values (mb/sec) to allow some head room
please post some logs with the aproprite parameters (you will need to .zip em)
all and all looks like a good start, and if its working like you say should just need some minor touches
Old 09-18-2009, 03:24 AM   #6 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
how can i open these files? everytime i try i get some scription code...sorry comp newb
JnR:
blue209 12.23@118 w/1.8 60ft 321hp and 390tq
tkilla 12.28@117.8 w/1.8 60ft new e85#'s coming soon
jrsrt 12.29@116.9 w/1.87 60ft
blackpearl 12.35@114 w/1.960ft 307hp and 363tq
Winecountry 12.32@112 w/1.7 60ft 315hp and 330tq
yellowsrt-4 12.5@112 w/2.0 60ft 307hp,355tq
jlozacr 12.7@110 w/2.0 60ft 301hp and 345tq
bayscksrt 12.9@110 w2.0 60ft 21psi, E85
srt princess 12.9@109 w/1.9 60ft
Kaz109 50 trim 458hp/460tq 11.54@121.78 W/1.79 60ft
reed32 is offline   Reply With Quote
Old 09-18-2009, 03:26 AM   #7 (permalink)
nutz's Avatar
Trader Rating: (19)
Download the latest version of AEMPro here. Also includes AEMLog!
that forum has some good info
Old 09-18-2009, 03:31 AM   #8 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
thanks nutz
Old 09-18-2009, 03:50 AM   #9 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
still having problems viewing this log.....says can't connect to ecu...work online or off line
Old 09-18-2009, 04:03 AM   #10 (permalink)
nutz's Avatar
Trader Rating: (19)
yes DONT try to connect, it took me 5 months to figure that out when I first got the EMS
Old 09-18-2009, 04:11 AM   #11 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
still no luck for me....fuuuuuuuuuuuuuuuck
Old 09-18-2009, 06:08 AM   #12 (permalink)
nutz's Avatar
Trader Rating: (19)
ok, lets start by selecting the aproprite O2 sensor in your sensor setup, then set the sensor gain, make the sensor and gauge read the same if its a eugo box dont wory about that last step. then go to the fuel<o2 feedback<o2 sensor wizard and select the correct sensor again (copy your FB map first so you can paste it back up). your FB cuts out at .91 psi so you have no load control, if it was me i would make a back up copy of this map (just incase) then set all the original settings from the 1510 base map in the O2 FB area and start tuning your FB again O2 feed back
Old 09-18-2009, 06:44 PM   #13 (permalink)
The reason there is no o2 sensor configured is because i changed all the settings. I'm running an Innovate wideband and the numbers are way way out when you compare the actual AFR to what the AEM sees. After dealing with AEM a bunch on this I was able to go in with the laptop and change the settings of both the LC-1 and the AEM so now they read the same. Because I changed the afr/volt table it unchecks the O2 sensor I have.
The base settings are way of. It ossilates way to much before it reaches the target O2. I've been playing with it but i really dont know what im doing when it comes to that.
Im still working on the boost fuel table so I turned O2 feedback off under boost.
I dont know whats going on with the idle very much. Tried a million things but still working on it. I only recently figured out how to get it to run off the maps. (TPS voltage thing)
I recently got rid of my AVC-r and am now using the EMS to control boost, so i'm tuning as I go. I havnt gone over 16PSI with the new tune (ran 24 before, but not full boost comp) So still working on the fuel/timing for anything over that.
Old 09-18-2009, 07:02 PM   #14 (permalink)
nutz's Avatar
Trader Rating: (19)
if I was you I would set up that sensor and use the sensor gain to match it up. once its set up correctly I think you will be plesently suprised
setup>o2 sensor>options
Old 09-18-2009, 07:20 PM   #15 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
One thing regarding your hot start issue. You may want to check out how quickly your wideband is sending a true AFR signal to the EMS for it to make corrections off of.
I know on my Zeitronix unit, it takes about 26 seconds to warm up (regardless of temps) before it starts sending a true AFR signal to the EMS. During the time that the sensor is warming up, it sends a false signal to the EMS that, in my case, would usually read rich in the EMS, and as such, the EMS would try to compensate for it with O2 feedback. This would cause the car to run horrible on hot starts.
To fix this, I set a static value of 26 seconds in the "Start Extra Decay Table", so that the EMS doesn't make any corrections off of the signal from the wideband until it is actually reading and sending a correct afr value.
MY FAVORITE EQUATIONS:
Fuel Volume = (HP * BSFC) / (# of injectors * IDC)
CFM = C.I.D. * RPM * V.E. *.5 / 1728
P.R. = (PSI Boost + 14.7) / 14.7
HP = TQ * RPM / 5252
Page generated in 0.21058 seconds with 14 queries
