08-04-2006, 02:33 PM
#1 (permalink )
Member Number: 20976
50 trim map with 12 cams
heres a recent map of a very conservative tune on an agp 50 trim
standard 50 trim
supporting fuel 750 injectors
this was setup using an mbc set at 20 psi on pump gas.the car made 395whp@20 psi
use at your own risk ,im not responsible for anything downloaded off this post
08-04-2006, 03:03 PM
#2 (permalink )
Member Number: 3622
awsome, thanks for posting!!!!! which injectors are you using? rc? dworks?
good numbers on very reasonable boost levels. who tuned it?
-Soren Kierkegaard
08-04-2006, 03:23 PM
#3 (permalink )
rc 750 injectors.we tuned it,we have an offsite dyno
08-06-2006, 07:18 PM
#4 (permalink )
Member Number: 30867
This should be a good starting map for us i think.
08-07-2006, 12:15 AM
#5 (permalink )
Member Number: 22976
base fuel pressure with vacuum source disconnected?
R.I.P. Steven Lorenz 04.04.06
My Slips .com
Bench Racing Stops Here.
Post up your SRT-4 Timeslips and rank in the
SRT-4 Portal
08-07-2006, 09:15 AM
#6 (permalink )
42 psi running the regulator off boost source
09-20-2006, 02:45 PM
#7 (permalink )
Member Number: 36680
standard 50 trim
why am i having a problem viewing the link/file?
09-21-2006, 10:20 AM
#8 (permalink )
dunno....save the calibration file to a the start up calibrations folder then go into aem pro and click open and open the file
09-21-2006, 01:11 PM
#9 (permalink )
thanks....what boost source did you use for the FPR?
09-21-2006, 09:41 PM
#10 (permalink )
the up pipe
10-31-2006, 04:34 PM
#11 (permalink )
Member Number: 1745
Stock bottom end?
04-25-2007, 05:18 PM
#12 (permalink )
Member Number: 50867
What program do I need to open these maps up and view them
04-26-2007, 08:18 AM
#13 (permalink )
you need aem pro
Linear Mode
» Site Navigation
> Other Vehicles
» Buyers Guide
» Network Links
