Old 01-24-2008, 05:02 PM   #16 (permalink)
NoisufnoC's Avatar
Member Number: 136
Quote: Originally Posted by cacahead View Post
yea i put the stock map sensor back on, i was sure the car wasn't suppose to lobe like that. And the only reason i bought the 3 bar was because i put my boost controller on, and my CEL came on with an oveboost code.
how much boost?
GTFO with your Stage 0 Nonsense!!
omgz!! i haz mods!!
NoisufnoC is online now   Reply With Quote
Old 01-24-2008, 06:49 PM   #17 (permalink)
fivetoez's Avatar
Member Number: 9691
Quote: Originally Posted by NoisufnoC View Post
what is lobe?
It's the fleshy "clit like" bump, on the lower part of your ear(Sorry:I thnk KorterHorSe has assimilated me.......
Now a LOPE...............is what an engine w/a heavy cam does @ idle
_____5TOEZ______ 1967 Cadillac Calais 429 2dr., 1967 Chevelle 4sp. Conv. ,1978 Dodge 318 "Factory Custom"van., 2004 Dodge Srt-4,Stage.1(E-Blue) & a couple motorcycles.
Old 01-26-2008, 11:07 PM   #18 (permalink)
Member Number: 58932
Quote: Originally Posted by $PK$ View Post
I laughed after reading every reply to this thread
On a serious note, its only bad if you only run the 3 BAR map sensor and not the TIP. You won't see the 50whp gain on only the 3 bar map, you need the 3 bar tip also
and i laughed at your "legit" response.
you DONT NEED the 3bar tip at ALL when running a 3bar map...that is, if we are dealing w/ the s2 pcm. if you remove the red/white vac lines, running the tip sensor is useless.
in short,
run the 3bar map on the s2/3 pcm.
s0/1 pcm is NOT calibrated for the 3bar setup.
Old 01-26-2008, 11:26 PM   #19 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (24)
in short,
x2 no need for a 3 bar unless you are running a 2/3pcm
JnR Performance=envied by many in norcal
Sponsored by DCR
reed32 is online now   Reply With Quote
Old 01-26-2008, 11:51 PM   #20 (permalink)
JesseL's Avatar
Member Number: 51882
Trader Rating: (21)
Damn, your probably losing major crank horsepower
Betcha I'm not!
I have a s0 pcm with a 3bar map! (and no tip!)
<3 throwing out random info that needs a back story
JesseL is offline   Reply With Quote
Old 01-27-2008, 12:33 AM   #21 (permalink)
Quote: Originally Posted by JesseL View Post
Betcha I'm not!
(and no tip!)
betcha your tune aint what it could be if you went s0/2.25bar map or s2/3bar map!
tro0f!
Old 01-27-2008, 02:00 AM   #22 (permalink)
JesseL's Avatar
Trader Rating: (21)
Car isn't running off the s0 :p
Its running off the AEM EMS
Old 01-28-2008, 09:10 AM   #23 (permalink)
Member Number: 59439
it was only at 15 psi... i heard the stock map sensor was good for 18 psi. So i dont know why i got the overboost code, but mine is a 05 srt4 i als heard those are a lil more sensitive... not sure what is mean't by sensitive, but is it true?
cacahead is offline   Reply With Quote
Old 01-28-2008, 11:09 AM   #24 (permalink)
DOH!
my mistake.
Old 01-28-2008, 11:32 AM   #25 (permalink)
19 psi's Avatar
Member Number: 12457
Trader Rating: (37)
bl0l at name....meh, doubt problem cause for any alarm but unsure untill you log all parameters
19 psi is offline   Reply With Quote
Old 01-28-2008, 01:40 PM   #26 (permalink)
just wanna say thanks... so thanks lol
Old 03-07-2008, 01:49 AM   #27 (permalink)
srtred1's Avatar
Member Number: 59362
still have stage 2 map and tip sensor? pm and lets talk some buissness
srtred1 is online now   Reply With Quote
Old 07-18-2008, 08:51 PM   #28 (permalink)
d4dulla's Avatar
Member Number: 49986
can some1 please explain to me what a 3bar/tip sensor is? hurd it just makes u hold more boost or sumthing. i was wanting to get one but have no idea about them. i'm stg3 w/ stg0 pcm. my buddy has the 3 bar sensor (or tip sensor w/e its called) on stg0 pcm and has 416hp
F/S- E-cutout DP ($200), 3" O2 housing ($60)
d4dulla is offline   Reply With Quote
Old 07-18-2008, 10:01 PM   #29 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (28)
your buddy has a stage 2 or 3 map sensor on a stock pcm and he is making 416? id love to hear all the missing details on that one...
beyondspexj is online now   Reply With Quote
Old 07-20-2008, 08:56 AM   #30 (permalink)
d4dulla's Avatar
of corse he's going to have a lot of mods to have that much hp but he's stock pcm. Modern Mopar of East Tennessee
