Can somebody school me on the difference between 3 bar and 4 bar?
bar is a measurement of pressure. The more pressure you run, the more your injectors will flow. We used to rate ours at 4bar (58psi), but now we rate them at 3 bar (43.5 psi).
The ONLY drop-in High Flow SRT4 injectors
Group Buy in progress... click HERE
So basically they are the same flow rate just measured differently, what are some normal power gains for your 590cc injectors. Stage 1 (or 04-05 stock) are 577 cc, are there really some noticeable power gains going from 577cc to 590cc?
Actually our stage 1s flow 577 @ 4bar, DW Stage 2s flow 650cc @ 4 bar.
When the Stage 1s are @ 3 bar they flow 500cc, and the DW Stage 2s flow 590cc @ 3 bar.
Alrighty so If i have stock 05 Injectors and looking to get 750cc injectors also have the stock Fuel rail these will plug and play no soldering or nothing to install and I will get a core return of how much for all four??
::Stg 1 PCM::AEM S.R.I::Hallman MBC::Borla Dual Exhaust::NeedsWing v5 3" DP/Cuttout::Turbonetics Cold Side Pipe w/ Greddy Type S.BOV::Mpx Front Mount Intercooler::Tein-S Springs::AEM EUGO,OIL Pressure,Volts::Apexii TT::Apexii Neo/MSD Tach::Bwoody Motor Mounts::IP2 CF Hood::Carbon By Design Eyelids & Radiator Shroud::AGP Return Line::AGPBB50trim::RC750cc::Walbro255
