No WOT shifting, @ Lapeer Dragway (this was the worst track I have evar ran @, the 60' was full of oil dry and and unprepped. I was bouncing the tires in the wheel wells to about 45MPH.
Year 04
Toys Yes
DAB Setting 2
Racegas Yes
Tires 712s (225) 25PSI
Exhaust 3" TB
Boost Leak checked? Yes
Had Leaks? Yes (still have a small leak around the fogger)
Please keep this on topic(reference #'s only), if you want to discuss something w/ the individual shoot em a pm or start your own thread. Thank you!!! Oh wait, I'm not glhs you are. j/k
I went back to the track the other day....after putting in a bleed mod to get my PSI up to what others have with just the stage 2 (why I have to have bleed mod to hit over 13 PSI baffles me still).
Since then I have leak tested....I found a big leak on the hot side intercooler pipe. But my boost is down low again temporarily because I took the bleed mod off for testing purposes...freaking 13 PSI.
All runs on stock tires...mopar exhaust...STS...top mount inserts...
interesting night. previous best is toys not installed 13.259 (hitting limp mode at very end, blah blah blah)
added toys, used race gas & hit the magical button.
'03 with toys, 3" exhaust, no boost leaks, pilot sports at 22psi hot, k&n air filter, extreme srt-4 race intercooler and mopar sts.
4 runs, on the 2nd i forgot to hit race gas button, all on dab 3.
Year 2003
No Toys
Exhaust tips removed
Boost controller set to 24 lbs
101 Trick Fuel
5400 Feet elevation 7 Tenths slower from Sea level ( Approx ). The air was bad that night everyone was running 2.5 tenths slower than normal...
stock otherwise
13.98 @ 100.4 1/4 2.21 60'
Year: 2004
Toys: Yes
DAB: 3
Gas: 93 Pump Gas
Intercooler Sprayer: auto
Race-gas button: off
Tires: Stock BFGs @ 22 psi
Launch Technique: let clutch out fast @ 2,700 RPM's
Shifting: No WOT shifting @ 6,000 (at least on this run, wish I woulda WOT)
Exhaust: Modern 3" full exhaust
Any other mods: STS, BOV, Stock air box with K&N.
Weight reduction: Spare tire removed
Boost leak checked: Yes
Boost leak checked since: Nope
Leaking boost: Yes, only hit 15-16 psi
Weather: 77+ degrees, 94 (%?) humidity
Elevation: ???
Best run:
No burnout
R/T....... .224 (doh!)
60'...... 2.088
330'.... 5.859
1/8..... 8.923
MPH.. 81.35
1000. 11.525
1/4....13.755
MPH.. 101.37
Best MPH was 102.97. As you can see from the above time, my 60' somehow rocked for worn stock tires, but I do believe I'm leaking boost as evidenced by my trap speed and boost levels (only hit 17 psi momentarily in 3rd).
New 1/8 mile personal best, no race fuel this time just 93 octane. 23" M&H's set at 14.5lbs. D-A-B 3, race gas switch off. 78 degree's and very high humidity 90%-100%.
