Here is the lastest on my S2. First session was no better than stock. 14.19 Did Ghetto exhaust and picked up 2 tenths to a 13.79. That told me I need better breathing to make this thing work. Have now added K&N CAI and 3" O2 withHP 3" Exhaust.
Here are results from 6/22 at dragway 42 in Ohio. (Not great track prep)
S2 w/toys
Checked for leaks....do have a tea kettle whistle at higher RPM but I think it's a bleeder on the Vacuum sylnoids.
Dab 3
RT .006
60' 2.029
330 5.723
1/8 8.782
MPH 79.92
1000 11.38
ET 13.643
MPH 101.56
DAB 3 w/Race Gas (barely enough to mix, but light stayed red )
RT .027
60' 2.15 If I could of gotten another 2.02 this would have been in the 13.40s
330 5.873
1/8 8.867
MPH 81.83
1000' 11.40
ET 13.56
MPH 105.86
Bottom line with S2, let it breath. I think slicks could get me close to 12s
Word of advice.... Just stop now before it gets worse... Let it all wash away... This post backs up your post count. You might be able to bench 300lbs, but this internet is Serious Business and you are not ready....
Best time was 13.408@104.11 Best 1/8 was 8.747. 100 degrees w/ 45%humidity, elevation around 1500ft. These conditions hurt topend badly, look at my 1/8 mph. 22mph gain should be about right and I only gained 19. I gained 21mph on a 13.5@103.32 run. 12's are attainable w/ good conditions and better 60ft.
I went to Nopi today (Great time btw) and here are my results
Year: 2003
Toys: No
DAB: n/a
Intercooler Sprayer: n/a
Race-gas button: n/a
Tires: 225/45/17 Nitto NeoGen 30 psi
Launch Technique: Leave at idle (very bad traction so no WOT 'till 2nd)
Shifting: No WOT shifting
Exhaust: ATP 3" DP with cat and 3" B&B CB
Any other mods: AGP CAI
Weight reduction: Removed spare and jack
Boost leak checked: No
Boost leak checked since: No
Weather: 80 ish
Elevation: ???
a new best for me. .031 seconds and 2.99 mph better
mods from bone stock: stage 2 without toys installed yet, 3" exhaust, no boost leak check, pump gas, 17" gforce drag radials (same 60' times as me on pilot sports) & freshly reset ecu (was throwing a code caused by stage 0 tip sensor)
60'........2.155
330'......5.813
1/8.......8.707
mph......84.28
1000'....11.226
1/4.......13.329
mph......108.89
vid soon.
j.r.
p.s. OzSpeed ran a 12.8 on im pretty sure stage 2 + slicks only!
i will pm him the link to this thread
Year: 2003
Toys: no
Gas: 93
Tires: G-force drag radials
Launch Technique: drop clutch, ease into gas.
Shifting: WOT through all gears
Exhaust: ATP downpipe w/cat B&B cat back
Any other mods: STS, booger bushings, AGP CAI, eibach springs and prothain bushing kit.
Weight reduction: spare tire and jack out, lots of tools and air tank in so it was off set.
Boost leak checked since: Not yet
Weather: 85 degrees, high humidity
Elevation: 1800+ maybe even around 2000 not shore though.
60’- 2.108
1/8- 8.926
¼- 13.947
MPH- 96.76
There was a guy there that said he runs around 13.8 consistently at his home track but was running 14.4 all night so I would say my best time would have been around 13.3-13.4 at a sticky and lower track.
I should be considered the best seller on her as my customer service rivals every vender on here, well except AGP and Hector and I would say I'm as good as them Especially when you consider people come to me for help when Hector terns them away since they did not buy there stuff from them.
id start with ecu reset & the boost leak check. thats about as far as my knowledge goes. i usually turn to my left or right or my phone and ask MySRTfriesrice. he = my crew chief.
Still no good.
First trip to the track stock.
04 SRT Bone Stock/ Shift 5800 WFO
60' 2.25
330 6.14
1/8 9.28
MPH 79.79
1000' 11.93
ET 14.22
MPH 99.55
STAGE 2 Only Same Everything/ Setting 2/ More wheel spin
60' 2.32
330 6.13
1/8 9.25
MPH 79.96
1000 11.88
ET 14.19
MPH 98.48
STAGE 2 Ghetto Exhaust/25PSI softer and shorter tire/Race GAS mode/Sprayer/
60' 2.11
330 5.90
1/8 8.96
MPH 80.06
1000 11.58
ET 13.79
MPH 105.42 Looks like I need a 3" downpipe. and a CAI?
I removed aircleaner and it went slower. 60' is decent, Where am I loosing ET? It's got the MPH when shifted at the right RPM.
Ya if your stock exhaust your losing like 20-30hp without downpipe n all just an intake and exhaust i bet youd run low 13's for sure i see people with stage1-2 upgrade and their cars after spending 1200 bux arent barely faster lol
new best again.
same exact setup, did boost leak check and found none.
mods from bone stock: stage 2 without toys installed yet, 3" exhaust, no boost leaks, pump gas, pilot sports at 23 psi hot. **oh yeah- k&n air filter, extreme intercooler and mopar sts, been forgetting to list those three.
60'.......2.132
330'.....5.744
1/8......8.633
mph.....85.88
1000....000 (zeros all night for everybody)
1/4......13.259
mph.....105.79
