Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Time Slip Database
Old 02-25-2008, 08:43 PM   #211 (permalink)
rotomanrx2's Avatar
Member Number: 48106
05 stage 2 w/t
24/8.5-15 slicks 12lbs.
110 oct. on
23 lbs boost, Sts ,mamoth mani
60 ft. 1.834
reaction 0.123
1/8 8.064
miles 95.58
rotomanrx2 is online now   Reply With Quote
Old 05-31-2008, 07:13 AM   #212 (permalink)
Member Number: 60369
60 foot - 2.020
330 foot - 5.468
1/8 mile - 8.286
1/8 MPH - 89.02
1000 Foot - 10.745
1/4 Mile - 12.839
1/4 MPH - 106.07
On 225/45/17 BFG DR's
Boost 23/16
Bogged and spun first, hooked hard 1-2, powershifted all shifts (explains my high 1/8 MPH)
Have a leaking check valve (not bad) and a slight leak on my BOV.
Still trying to figure out my low 1/4MPH
s3 turbo, SCT prp, some giggle juice
Old 05-31-2008, 07:20 AM   #213 (permalink)
Elected Moderator
stowaway's Avatar
Member Number: 3286
that's too much boost. you're running the same mph (slightly better ET) than what a straight S2 car runs, at 16-18 psi dropping to 14-16.
Old 05-31-2008, 07:53 AM   #214 (permalink)
With race gas and the bfmic, i thought i was ok, and the car def. feels stronger low end with that high spike, versus the 18 spike (cant even break the tires at that psi).
Old 05-31-2008, 10:29 AM   #215 (permalink)
Elected Moderator
stowaway's Avatar
Member Number: 3286
yes, the low end feels good, but you're pulling timing up top killing the far end of the track. You're only gaining 17mph whereas people with less boost and mods are gaining 21-22mph.
Old 05-31-2008, 03:22 PM   #216 (permalink)
Hows that? We all end up at 16psi at redline?? After the spike around 3500 or so, we all are pretty much holding the same psi i thought?
Old 05-31-2008, 03:57 PM   #217 (permalink)
Elected Moderator
stowaway's Avatar
Member Number: 3286
the pcm sees the huge psi, high IAT, and possibly some knock and things go downhill after that. Unless you do some work to the turbo itself you are not really making any more power up above 20psi because the air is so hot and you're past the compressor efficiency point. It isn't a big turbo where you can run 25psi all day long... I'm just saying look at your numbers. With those times and mph up to the 1/8th you should be running better by the 1/4.
Old 06-15-2008, 05:18 PM   #218 (permalink)
jxmann's Avatar
Member Number: 57530
i have to say currently i am running stage 0, 3inch tbe w/o2, agp wga, sri, and ebc and i was running the same times as you all on s2, ill have my s2 installed tom. w/a 4" bfmic, and ill be at the track on the 21st and ill post my times but it wont have toys
jxmann is offline   Reply With Quote
Old 06-16-2008, 06:34 AM   #219 (permalink)
There are 200 some odd posts here, plenty of well tuned s2 guys are running in the mid to high 12's. Please post up your times on s0 so we can compare your before and after.
Why did you go with s2 if you are already getting the same times? Some would agree that s2 is a waste of money compared to a well tuned s0.
Old 06-16-2008, 10:10 AM   #220 (permalink)
jxmann's Avatar
lol im currently pretty much a broke bitch until i deploy, so im just putting it in for better fuel maps, im trying (key word trying) to avoid buying shit i dont plan on keeping...but ive got about 1200 in shit i dont plan on keeping...but it will all come together in the end...i hope...oh and currently my best is 13.89 on street tires (rikken raptors), but w/slicks and s2 w/some other supporting mods im hoping for 12.5 or even lower w/the help of a cooling mist s3
Old 06-16-2008, 11:09 AM   #221 (permalink)
So then you def. were not running the same times as s2 guys currently, or even other s0 guys currently. Heres what would have been my suggestion, get a mapclamp (or disconnect your redline and cap to hide boost) and do an fpr mod, turn up the boost to about 19psi, for about $80 you could have had a 13.0 car.
PM me if you need some links to mod advice, we should keep this thread clean from anything but drag times.
Old 06-18-2008, 11:07 PM   #222 (permalink)
SwizzSRT's Avatar
Member Number: 19724
Trader Rating: (17)
Car:
2004 Stage 2/w toys
Mods:
toybox 2.0, agp mm, needswings dp, k&n drop in, fm wga, big fmic
Tires:
Goodyear eagle f1
Boost leak tested: no
Boost leaks: idk?
Boost leak tested after: nope
1st run:
Dab: 1st 0, 2nd 2, 3rd 3, 4th 3
Hom: yes
Launched at 1500ish
60' 2.104
330 5.717
1/8 8.617
MPH 85.85
1000 11.120
1/4 13.209
MPH 108.39
SwizzSRT is online now   Reply With Quote
Old 09-28-2008, 03:01 PM   #223 (permalink)
EssOurTeaFour's Avatar
Member Number: 55818
Trader Rating: (25)
Stage 2 w/o
3" downpipe and exhaust
3" intake
front mount
kinetic wg @ 20psi
225/50/15 BFG DRs at 15 psi cold on PT steelies
50 psi in rear tires
Track prep was awful, in addition to that this was my first time at the track
.8680 reaction
2.2150 60ft
5.7749 330ft
8.6490 1/8th
87.04 mph
13.43 1/4 ET
93.75 mph
gained 6.71mph?? 1/8 to 1/4 did I back out to early on a low 13 run?
.6339 reaction
2.1633 60ft
5.7941 330ft
8.7540 1/8
85.21 mph
13.52 1/4 ET
100.65 mph
gained 15.44 mph?? from 1/8 to 1/4
No boost leak test was done before, car was just put back together and I had no time, car felt stronger before....
My mph seemed low, I also feel that I backed out at the end of the track, it wasnt clearly marked
Wanted a low 13, really a 12.9X
EssOurTeaFour is offline   Reply With Quote
Old 09-29-2008, 07:12 AM   #224 (permalink)
Quote: Originally Posted by EssOurTeaFour View Post
04
Stage 2 w/o
3" intake
front mount
kinetic wg @ 20psi
.8680 reaction
2.2150 60ft
5.7749 330ft
8.6490 1/8th
87.04 mph
13.43 1/4 ET
93.75 mph
.6339 reaction
2.1633 60ft
5.7941 330ft
8.7540 1/8
85.21 mph
13.52 1/4 ET
100.65 mph
What gas were you running? Any piggy back or wideband?
Old 09-29-2008, 07:36 AM   #225 (permalink)
Trader Rating: (25)
93 pump . no piggyback or WB
