Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Time Slip Database
Old 06-04-2008, 09:03 AM   #1 (permalink)
Member Number: 53168
Default sct 50 trim 18.5psi
the races were done on cheep street tires with 40psi in them; mods r 50 trim (18.5 psi) dw 750's, agp mm, mpx intercooler, cai, dtec fc\bc (fuel zeroed out), qtp down pipe electric cutout(open), stock clutch, sct tuner (canned tune from agp)
here are my best two of the night
r\t .182
60 2.169
330 5.766
1/8 8.545
mph 90.37
1000 10.889
1/4 12.870
mph 114.14
r\t .093
60 2.194
330 5.799
1/8 8.604
mph 89.67
1000 10.956
1/4 12.947
mph 113.62
sct seems to work really good i need to put my clutch in, up the boost, and invest in slicks or DR
theslacker is offline   Reply With Quote
Old 06-04-2008, 09:12 AM   #2 (permalink)
sti_zee's Avatar
Member Number: 40201
nice r/t, nice 60', nice et's, especially for a slacker.
love to see what that does at 20-22 psi.
'sti_zee' is neither a reference the wrx sti nor the 350z
sti_zee is offline   Reply With Quote
Old 06-04-2008, 09:26 AM   #3 (permalink)
thanks, when i get some DR ill up the boost in 1st and 2nd from 14psi to 16-18psi and see what she does then install my clutch and run 20-22psi
Old 06-04-2008, 11:05 AM   #4 (permalink)
ReDsRtKiD's Avatar
Member Number: 46248
Trader Rating: (10)
That's a pretty nice trap for only 18.5psi. You just need to invest in a clutch and crank that boost up and it will really wake up.
(Old Set-up) BB .50 Trim
12.8 @ 118 Traction>Me
(New Set-up) HTA35R+EMS
11.8@114 Breaking up through 4th
60' 1.70 1/8 7.6@95
ReDsRtKiD is offline   Reply With Quote
Old 06-04-2008, 02:00 PM   #5 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (114)
Thats not too bad. Your driving is very good to run 12s on street radials at 18.5. Nice runs
12.0@120 on DRs and 93oct.
addictedtosin is offline   Reply With Quote
Old 06-04-2008, 02:15 PM   #6 (permalink)
thanks, i've raced at the track many times but fwd is a diff story with a little more practice i should cut my times down more. I'm looking for mid 12's on 18.5psi
Old 06-04-2008, 02:37 PM   #7 (permalink)
Member Number: 51111
Very nice...I concur with what you're doing...Mastering 18.5 with mid 12's before cranking up the boost. I want to say I bet that tune you have is probably conservative too, should look at cleaning it up a little, could pick up another 2mph on your trap probably
lVlemphizStylez is offline   Reply With Quote
Old 06-04-2008, 04:16 PM   #8 (permalink)
Canada Moderator
Pablo's Avatar
Member Number: 1081
Very nice, was this on the .63 or the .48ar?
Pablo is offline   Reply With Quote
Old 06-04-2008, 04:26 PM   #9 (permalink)
.63ar
Old 06-04-2008, 04:50 PM   #10 (permalink)
Canada Moderator
Pablo's Avatar
Member Number: 1081
I don't see a returnline, do you have one/ If so what's the base pressure.
Old 06-04-2008, 04:58 PM   #11 (permalink)
with the SCT tune he doesn't really need one does he? The software should be able to control the injectors to it's liking up to the max duty cycle. Or am I not understanding this SCT flash?
Old 06-04-2008, 05:48 PM   #12 (permalink)
Member Number: 33203
It can be used with or without, not sure if there would be limitations without the returnline using sct or not, I already had one when I went sct so I didnt look into that.
Looking for rc1000s-1200s and a fullblown twin pump setup, PM me if you have either.
SCT tuned by AGP!
turbojonsrt4 is offline   Reply With Quote
Old 06-04-2008, 06:15 PM   #13 (permalink)
yes i have a return line at 50psi, but with sct u dont really need one, but its recommended
Old 06-07-2008, 04:59 PM   #14 (permalink)
srt4does13s's Avatar
Member Number: 42963
Trader Rating: (37)
i dont see how you are running those times. on my 57 trim i spin till 4th gear on the same boost levelof 18 psi
srt4does13s is offline   Reply With Quote
Old 06-08-2008, 02:14 PM   #15 (permalink)
Maybe you should invest in a set of tires then. I've had 4 different aftermarket turbos in the past few years and have made over 400whp and still only spun in 4th gear once to my knowledge. Try some of these, I still blow them off in second on pump gas and 20 psi, but they should help you even more than they help me.
Page generated in 0.18343 seconds with 11 queries
