Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Time Slip Database
Old 03-22-2009, 03:52 PM   #1 (permalink)
CIVICEATER's Avatar
Member Number: 16703
Trader Rating: (12)
Default New best time for me 11.87 at 118.94 mph
Well today I went to Atco and it was packed. Ended up getting 3 runs in. First runs went 12.73 at 115 mph missing 3rd gear. My second run was the best to date with a 11.87 at 118.94 mph with a 1.86 60'. My last last pass of the day was a 12.004 at 119.24 mph with a 1.95 60'. Boost was set at 22 psi and I was running Q16 race gas, but was still getting kicked out of HOM around the 1/8 mile once my fuel system is complete and I can hold HOM and turn the boost up a pound or two I dont see a problem with the car going 122-123 mph.
Track Day with new Time 11.87 at 119 mph Video by Fernando - MySpace Video
2003 Solar Yellow SRT-4
FFP 47LB Stage 3
Coolingmist Trunkmount Kit with Varicool Controller
MPx 3" Exhaust
AGP Intercooler
AGP CAI
Diablosport Tuner
11.87 - 118.94mph
^^22PSI on HOM (getting kicked out) and no tune
CIVICEATER is offline   Reply With Quote
Old 03-22-2009, 07:14 PM   #2 (permalink)
porksword's Avatar
Member Number: 66925
Trader Rating: (21)
Sounds good, are you running slicks or DRs? Get it nailed down and it sounds like you would be a good race with 95neonman who also just posted a new times thread.
porksword is online now   Reply With Quote
Old 03-22-2009, 07:19 PM   #3 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
not bad! what are your fuel mods that your gettting kicked out of HOM?
Pittsburgh Penguins 14-8-0 28 points
Old 03-22-2009, 07:30 PM   #4 (permalink)
blackedoutsrt's Avatar
Member Number: 31771
Trader Rating: (25)
Is your car under S3 PCM control, or are you running something to tweak it a little?
blackedoutsrt is offline   Reply With Quote
Old 03-22-2009, 09:24 PM   #5 (permalink)
srt4me18's Avatar
Member Number: 50825
Trader Rating: (20)
looking good man, keep up the good work and get that 60' down...you should see mid 11's in no time
REALTUNED/BUILT by REALTUNE PERF. and powered by AGP TURBO DELTA HTA 60
10.97@136mph (not under full power yet)
The 6th realtune car to hit the 10 second club
srt4me18 is offline   Reply With Quote
Old 03-23-2009, 07:22 AM   #6 (permalink)
CIVICEATER's Avatar
Trader Rating: (12)
I was running 24.5x8x15 m&t slicks. For fuel i'm running a full s3 fuel system with 750's and a 255, but no bottleneck mod and it starts going lean on the top end and by redline its 12.5 af and as the rpm's go up you can see the fuel pressure go down. I think once I get my lsd and sbc s3 in (stock clutch still) along with an alignment and my fuel system done where I can hold HOM I dont think mid 11's will be a problem. Also I'm running a s3 ecu with a DSP but just use the dsp to pull a little bit of fuel on the low end I wouldn't even consider it a tune.
Old 03-23-2009, 11:38 AM   #7 (permalink)
CIVICEATER's Avatar
Trader Rating: (12)
Video added to the first post
Old 03-23-2009, 07:58 PM   #8 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (30)
Nice runs! Are you wot shifting all the gears? It didnt sound like you wot shifted 2nd.
What do you think the problem is with it kicking you out of HOM?
S256 non extended tip F/IC tuned by Aaronneon
11.88@116 1.74 60'
Old 03-23-2009, 08:42 PM   #9 (permalink)
CIVICEATER's Avatar
Trader Rating: (12)
I did not WOT 1st-2nd because I did on my first run and blew the slicks away when I hit second so I lifted 1st-2nd and WOT the rest. I think the HOM problem is lack of fuel. If I fatten up the top end I think it will be fine. I was also using q16 which is oxygenated and will lean it out a tad more. On pump gas and straight m1 meth (was running straight meth at the track yesterday also) in 3rd gear at 6k I was at 12.0 a/f. I'm sure with the q16 I was at 12.2-12.3 especially in 4th. If I get it down to 11.5 a/f I think it will hold. The car seemed to like the straight meth as I picked up almost 4 mph since the last time I was there (was running 115mph) I guess it kept egt's down. No timing or boost changes where made since the last time I was at the track either and was about 15 degrees warmer yesterday than the previous time.
Old 03-27-2009, 09:12 AM   #10 (permalink)
ade99's Avatar
Member Number: 17129
So you are actually able to tune your car with DSP in HOM mode? I noticed that it seems to always revert to the same tables when I turn HOM ON.
ade99 is offline   Reply With Quote
Old 03-27-2009, 06:44 PM   #11 (permalink)
CIVICEATER's Avatar
Trader Rating: (12)
No but I should be able able to change fuel as HOM is just a different timing map. It should use the same fuel map for HOM also. I have not used the DSP to really tune anything yet beside change fan temps and pull a little fuel on the bottom end.
Old 03-27-2009, 10:19 PM   #12 (permalink)
Trader Rating: (30)
Dont quote me on this, but I believe HOM is a little leaner on the fuel side, along with the massive timing it gives you! I read that somewhere on here, I believe neondan posted that, and I quoted it!
Old 03-27-2009, 10:33 PM   #13 (permalink)
ade99's Avatar
What about boost levels. Will you be able to increase boost in HOM? I found that my boost levels are always at 26 peak 23 @6K when in HOM even after I increased boost. I did notice the increase in boost when HOM was off. i was able to peak 28 and 24-25 @6K. The other odd thing is, I cannot seem to increase timing when HOM is off. The highest I got to was 27degrees @6K no matter how much timing I add.
Seems like I can't adjust both boost and timing at the same time. I either stick with HOM off and adjust boost while timing stays the same OR go with HOM ON with 35-36degrees @6K but boost stays at 26psi max.
Old 03-27-2009, 10:39 PM   #14 (permalink)
tavenger5's Avatar
Member Number: 42245
Trader Rating: (29)
great runs! I take it you don't have an LSD trans?
I gotta get to (that) track soon. In what span of time did you get 3 runs in?
[font="Arial Narrow"]
2004 Black SRT-4 - all set for 500hp+
2005 Interlagos Blue BMW M3
tavenger5 is offline   Reply With Quote
Old 03-27-2009, 11:46 PM   #15 (permalink)
bluebeast's Avatar
Member Number: 39695
Congrats on new best! Really good trap speed.
ROLL RACING isn't racing. It's just 2 homos speeding next to each other!
11.79 @ 118.53 S3 + bolt-on car!
BEST 60 1.68
bluebeast is offline   Reply With Quote
Page generated in 0.21803 seconds with 13 queries
