Left at idle on this run. No launch!
rt: .472
60: 2.36
330 6.214
1/8 9.343
mph 79.11
1000 12.016
1/4 14.307
mph 96.68
track is at 1,600 elevation
here are what other cars are trapping
5.0 mustang 15@90
ls1 = 14.3@103 lid/catback/converter
stock srt4 14.4@97
04 gto 14.7@98 drop in intake
cobalt ss 14.5@98 stg2,Honed manifold, downpipe,exhaust,drop in filter and something better to launch with.
05 srt-4
mods: stg 1, agp wga
no launch just pull out hit gas
track: Bristol
elevation: 1,615 with a slight up hill track
Best 1/8: 9.343
Best mph 79.11mph
Best 1/4: 14.307 (2.360) 60ft
Best mph 98.25
Well coming off the line idling is not helping. You are starting from scratch. It would be just like bogging your car real bad. You need to actually try to launch it. Get the 60' down to 2.1x something and you should be happier.
could be a few things but the launching is pretty major. did you re-route the vac lines when you did the wga and stage 1. whats your boost spike/hold? what was the air temp? temp changes can affect my traps speeds by as much as 6mph with my setup say going from 90 degrees to 55. get that 60ft down 2/10ths and you will drop 4/10ths off your et
2005 SRT-4 stock turbo and manifold stage 0 no spray. Basic Bolt-ons with driver mod
12.52@ 109mph slicks 1.7 60ft and 12.75@111 on gforce tires
standard 50 trim, intake, 3in dp, rc 750's, ngk wideband, fmic, msd wires, safc ii, cooling mist w/m injection, ptp stage 3 clutch,cp pistons, eagle rods, arp head studs,and dcr head gasket... best time is 11.8 118 on 24psi
I looked the car over found the red line was just tucked back no cap no nothing and the hotside intercooler had a small tore hose on it well it was wide open. So I took the red line and put it there car feels like it runs alot better and quicker. I wonder how much better time I could have gotten
I would if i could but that was the last event untill next year
it just bothers me because I think i could of got low 14 at least i had one hella boost leak lol
