Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Time Slip Database
Old 10-07-2007, 06:31 PM   #1 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (15)
Default Finally a damn 12!
Well First off this is my first time on slicks EVER. It was 90 + degrees outside and on this run I even pulled the shift knob off and missed 4th while doing itAll while having a boost leak from my Ebay catch can
R/t... .370
60... 1.99 (damn slicks)
330.. 5.484
1/8.. 8.384
mph. 84.60
1/4.. 12.98
mph. 107.11
AGP 44LB kit...382whp/416wtq
on 22psi and pump!
Old 10-07-2007, 06:32 PM   #2 (permalink)
t3turbo's Avatar
Member Number: 35136
Trader Rating: (35)
Not bad at all. Good run, I say.
AGP Garrett DBB 50 Trim
362 whp-371 torque @20 psi on 92 Octane
423 whp-434 torque @24 psi on 109 Octane
(freaks out the guys in Z06's )
t3turbo is offline   Reply With Quote
Old 10-07-2007, 06:34 PM   #3 (permalink)
busarich's Avatar
Member Number: 25901
Trader Rating: (32)
good job, change your sig.
MODS: Mostly stock
DYNO VIDEO - http://www.youtube.com/watch?v=NcQkdzEbry0
busarich is offline   Reply With Quote
Old 10-07-2007, 06:36 PM   #4 (permalink)
t3turbo's Avatar
Trader Rating: (35)
I tore the shift knob off on the street while shifting into second the first week I had my car.
I put a short shifter on it right away.
Old 10-07-2007, 06:40 PM   #5 (permalink)
bluebeast's Avatar
Member Number: 39695
Trader Rating: (12)
Congrads on 12's might as well shoot for 11's now!
ROLL RACING isn't racing. It's just 2 homos speeding next to each other!
11.79 @ 118.53 S3 + bolt-on car
bluebeast is offline   Reply With Quote
Old 10-07-2007, 06:55 PM   #6 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (23)
Good run! I finally made it into the 12's too! 12.88@108! It's a good feeling that all the money spent on mods paid off!
04 S3 11.90@114 Untuned PCM controlled!
BOOSTINSRT04 is online now   Reply With Quote
Old 10-07-2007, 07:09 PM   #7 (permalink)
Kason23's Avatar
Trader Rating: (15)
Yea I feel good about getting some 12's Im sure if I did not miss that gear it would of been 12.7 or so easy! I also need to work on my 60 foots 1.99 on slicks in not cutting it AT ALL!!!
Old 10-07-2007, 07:31 PM   #8 (permalink)
Figs's Avatar
Member Number: 52595
Trader Rating: (36)
Congrats! What are your mods?
Figs is offline   Reply With Quote
Old 10-07-2007, 07:42 PM   #9 (permalink)
Kason23's Avatar
Trader Rating: (15)
SSAC Big Front mount
Aem short ram intake
Cold side pipe with type S bov
Block off plate
kinetic Wga (21/15)
PTP fpr mod
PTP check valve
Ebay catch can(that leaks)
Maxfabb 3 inch dp
mopar cat-back
Safc II on a 11.6 afr
And some small 22 inch slicks at the time!
Old 10-07-2007, 08:23 PM   #10 (permalink)
Member Number: 30819
Trader Rating: (12)
race gas + low 12's AFR
2nd gear burnouts on slick until you see smoke (bonus style points if you get in cabin smoke while you're pulling up to the tree)
launch at 4500 rpms
WOT shift..
that trap reeks of 12.6 or 12.7 practice, practice, practice ^^
12.29 @ 110.75 1.67 60' on slicks
stock turbo on stage 0
summy is offline   Reply With Quote
Old 10-09-2007, 09:03 AM   #11 (permalink)
srtsofgadsden's Avatar
Member Number: 49842
welcome to the club
standard 50 trim, intake, 3in dp, rc 750's, ngk wideband, fmic, msd wires, safc ii, cooling mist w/m injection, ptp stage 3 clutch,cp pistons, eagle rods, arp head studs,and dcr head gasket... best time is 11.8 118 on 24psi
srtsofgadsden is offline   Reply With Quote
Old 10-16-2007, 11:12 PM   #12 (permalink)
srT4URBO's Avatar
Member Number: 37484
Trader Rating: (10)
i hope i go this sat...now its my turn lol if everything goes ok ill get it
Its modded
srT4URBO is offline   Reply With Quote
Page generated in 0.19148 seconds with 11 queries
