Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Time Slip Database
Old 05-30-2009, 06:41 PM   #1 (permalink)
elias's Avatar
Member Number: 55636
Default Crappy run today at Fontana 05/30/2009
Well first I will give my time slip then my mods list;
R/T: .139
60' : 2.322
330: 6.477
1/8: 9.870
MPH: 74.40
1000: 12.724
1/4 : 15.165
MPH: 93.32
Here are the mods;
AEM CAI, MSD Coil, ACT Street Clutch W/ Lightend Flywheel, Mopar Wires, Eibach Pro Springs, ATP Cold Pipe W/ HKS BOV, BWoody Solid Motor/Trans Mounts, NRG Catch Can.
Tires;
245/45/17 Falken Ziexs
Pressure: 35psi (stupid!!!! forgot to drop pressure!!!!)
Why is it that I can't seem to get out of the 15s? I have a great set up on basic bolt-ons, need some advice if possible. Thanks!
Next mods:
E1 from Forward Motion, Tokico Illuminas( to replace blown stockers) and Mopar stage1 PCM.
** If you have any suggestions please input**
** Other than slicks. I like my axels to damn much =) **
elias is offline   Reply With Quote
Old 05-30-2009, 06:47 PM   #2 (permalink)
Member Number: 67038
you are WAYYYYYY down on horsepower. like serious. what is the boost at. i bet you have a boost leak and a huge one at that. and check your compression and let us know what the numbers are. you may have bigger problems.
Delta 55 Turbo kit, agp catch can, agp solid motor mounts,scangauge and wideband, 3 bar map and tip, Injen Sri, Jmb with hks, stage 1, exhaust depot custom undercar dump, grantelli wires,DW 750's, walbro. rescale by turbo 666
AllBoost is offline   Reply With Quote
Old 05-30-2009, 11:32 PM   #3 (permalink)
JoHnNysSRT4's Avatar
Member Number: 34468
i got the same problem today at fontana i couldnt reach 100 mph on my stock turbo on slicks with bolt ons..i had the slicks psi on 13.5 n i was launching at 4, 4 1/2 and 5 rpm..and nothing couldnt get better than a 14.1!!
R/T: .012
60': 2.078
330: 5.900
1/8th: 9.076
MPH 78.226
1000: 11.811
1/4: 14.137
MPH: 96.90
JoHnNysSRT4 is offline   Reply With Quote
Old 05-30-2009, 11:36 PM   #4 (permalink)
elias's Avatar
So I did a compression check on the engine, car was dead cold and also replaced the sparks plugs seeming how they had about 45+k miles on them. Here are the results of the test, then I have a funny story about the freakin' plugs!!!
Cyl. #1.) 155.00
Cyl. #2.) 155.00
Cyl. #3.) 155.00
Cyl. #4.) 152-153.00
I think that s pretty good,no?
Well the story; So first my friend and I were getting the tester all ready and I raced over here to find the "How To", pulled the first plug which was torqued to about 50+lbs and the gap on all plugs were at 58 or more!!!!
So I put the new NGK V-powers in at the recomended .035 and 13lbs of torque, took the car for a little test drive and The car feels 100% different! Now to take next weekend to do a boost leak test. Unless someone near me wants to drop on by to help??
Anyways I did the first recomended test and these are the results, any new insight.
Thanks in advance though. This site has always been a great help and stress relief.
Old 05-30-2009, 11:54 PM   #5 (permalink)
yes those numbers are not bad on the compression. thats good news. and you were lossing power for sure with those plugs. good eye on that to see it. once you do a boost leak test i bet you find mroe leaks and your car will feel fast as fuck. believe me, your running slower than stock. let me know how it goes with that boost leak test.
Old 05-31-2009, 12:29 AM   #6 (permalink)
elias's Avatar
Well, I do think my stock turbo has seen better days it seems to be leaking oil only on the outside on the exhaust side not the inlet side, so it is going into the shop on Wednesday or Friday for an inspection, but more or less am already seriously considering going a little modded with the E1 turbo.
Will do a boost leak test as soon as I figure out how to manufacture the damn thing. Thanks for the vote of confidence with the compression test. Car has a little over 85k miles on it and is still fun to drive no matter the e.t.'s on the track.
Old 05-31-2009, 12:19 PM   #7 (permalink)
ya with turbo in the hot side you prolly have a bad exhaust seal in there. i would get a fm e1 for something no to crazy but still with potential. i think with your mods you could really get alot out of one. i am going big turbo in the next few weeks. just waiting on the kit from agp.
Old 05-31-2009, 07:05 PM   #8 (permalink)
any one could help me out on why i cant trap a 100 mph? thanks
Old 05-31-2009, 09:22 PM   #9 (permalink)
do a boost leak test. that is the most usual problem with our cars. our turbos are so small that it is very hard for it to keep up with any leak.
Old 06-03-2009, 12:16 AM   #10 (permalink)
PUDGE...SRT4's Avatar
Member Number: 71257
instead of doing boost leak test, i zip tied every vacuum line possible and replaced all the stock clamps on the intercooler pipes with t bolt clamps and my boost leak was gone and the car felt way better.
13.40@109/FM e1 turbo
PUDGE...SRT4 is offline   Reply With Quote
Old 06-03-2009, 01:49 PM   #11 (permalink)
elias's Avatar
So that brings up the question what you are doing this Saturday? J/k How long did it take you to complete this?
Old 06-05-2009, 12:36 AM   #12 (permalink)
it took about a hour to do
Old 06-05-2009, 09:57 PM   #13 (permalink)
Louisvilleguy's Avatar
Member Number: 17118
You can build a boost leak tester for about $9 with parts from Home depot/Walmart. It's not hard or time consuming to do. I used to think crap, I don't want to go through this hassle until I did a test on the car one night. I found a few big leaks that I never realized were there and doing the test was easy to do and way quicker than I expected.
04 SRT-4
- FP Green model
- Diablosport tuned
Louisvilleguy is offline   Reply With Quote
Old 06-05-2009, 11:16 PM   #14 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (30)
To the OP Boost leak test your car! Even with zipties amd tightening clamps you could still have one! Also work on the 60's!
Jonny...take the same advice as above. 13.5psi in the slicks is a little bit high imho, I usually run 10psi in mine, and even on our not so good prepped local track i still cut 1.7s, are you WOT shifting?
Also what boost are you guys running? Do you have anything to monitor knock/timing, wideband? Theres so many different things that can make your cars not run what they should be!
Old 06-08-2009, 12:05 AM   #15 (permalink)
oh ok..last time i had em at 10 psi and my time was low cuz my car wasnt running right..but before it was running good i had em at 10 psi and i had a good time on the 1/8th i ran a 8.5 launching at 4..yeah wot..i shifted at 58krpm on that 14.1 but i had a the msd coil and 2 msd wires and 2 stock wires now i replaced everything back to stock..agp wga at 17 psi 03 stock injectors and stock ecu..so where are the most places in your car where you find the air leaking from?
Page generated in 0.19960 seconds with 13 queries
